2W900FM doesn't work if close to car
tomkang2000
Posted: July 05, 2006 at 2:20 PM / IP Logged
Hi, all:
I have stange issue, if pager 2W900FM(blue) is close by the car, it doesn't work, walk away from car for 10 feet, it works again; how ever 1 way remote always works perfectly;
I also tried to re-program the page, however because this issue, I can not program my page inside my car; I have to turn on and off key 5 times and jump out the car immidiately far for 10 feet, then it programed; 1 way remote can be programed inside without any issue!  any ideal? thanks!
jimmeezgolfvr6
Silver - Posts: 258
Posted: July 05, 2006 at 2:29 PM / IP Logged
sounds like you've activated a feature called "auto" by accident, which is done by pressing and holding onto button 1 for over 2 seconds. when this feature is activated, the alarm will automatically disarm when the pager is close to the vehicle, and automatically arm when the pager is far from the vehicle.
you can deactivate this feature in the same way....press and hold button 1 for over 2 seconds. there should be an indication on your display that this feature is on. good luck!
all problems can be resolved with a hammer
tomkang2000
Posted: July 05, 2006 at 5:04 PM / IP Logged
thanks a lot, that was execactly the issue!
Sunday, February 15, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
