bmw 316i compact 1997
bmw97
Member - Posts: 22
Posted: July 17, 2006 at 3:23 AM / IP Logged
i bought an aftermarket keyless entry and i want to install it. the car was not pre-wired for alarm\keylesss enrty , is there anybody can help me to locate the cental locking module and where is the lock and unlock wires .
tanx
12voltmaster
Member - Posts: 38
Posted: July 17, 2006 at 1:26 PM / IP Logged
tanx
Check this
https://www.the12volt.com/installbay/forum_posts.asp?tid=80388&PN=1
bmwpwner
Copper - Posts: 174
Posted: July 17, 2006 at 11:18 PM / IP Logged
yea, the last 3 series i did had the bcm below the glove box (for lock/unlock) and i grabbed everything else from the column as usual. good luck and hope this helps.
"I cannot teach anybody anything, I can only make them think."
-Socrates-
bmw97
Member - Posts: 22
Posted: July 18, 2006 at 3:07 AM / IP Logged
tanx for all ur suggestions and help. yesterday  i installed my keyless entry on my car and it was successful. How do i do that?  i focus on pin 16 &3, i removed the existing  wires  on pin 16 & 3 and tapped the lock and unlock wires of  keyyless entry to the pin 16 & 3 and  I soldered diode to each existing wires  that  i removed and tapped to the ulock and unlock wires  (keyless entry) and it works.       diode connection is facing away to the existing wires
Friday, February 6, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
