alarm not opening doors
plyrh8r1
Member - Posts: 31
Posted: August 18, 2006 at 2:33 PM / IP Logged
i have a 1993 ford escort with shaved door handles. i have auto poppers with a dei hornet alarm with remote start. my problem is that my doors dont open any more if i jump the wires to the relay thay work fine they just dont work off the remote. the alarm arms and disarms and starts the car. somebody said i might have to reprogram my remote to work the doors. thanks guys
duallyit
Member - Posts: 17
Posted: August 18, 2006 at 6:08 PM / IP Logged
you may have to set the remote in programming the door pulse to a double pulse check that out see if that dont help you out
duallyit
swamprat323
Gold - Posts: 1,335
Posted: August 19, 2006 at 9:57 PM / IP Logged
meter the wires form alarm see if you have "output"
plyrh8r1
Member - Posts: 31
Posted: August 21, 2006 at 8:27 PM / IP Logged
how do set the pulse
swamprat323
Gold - Posts: 1,335
Posted: August 22, 2006 at 7:22 PM / IP Logged
look in the install guide, programing, it tell ya in there, if dotn have the install guide look in the down laod sections see if its in tere, if not post what system you have here.
plyrh8r1
Member - Posts: 31
Posted: August 25, 2006 at 3:22 PM / IP Logged
i have a dei hornet 553t with a dei channel expander 450r i didnt see my model in the download
swamprat323
Gold - Posts: 1,335
Posted: August 25, 2006 at 5:22 PM / IP Logged
the hornet 553T is now in the download section.
geofbettis003
Member - Posts: 21
Posted: August 25, 2006 at 5:27 PM / IP Logged
have you tried reading the alarm with a bitwritter? if not give it a shot, you might want to look at the "ignition controlled locks" section
plyrh8r1
Member - Posts: 31
Posted: August 27, 2006 at 9:39 AM / IP Logged
i dont have biwritter. thanks for the download. i think i might just take it back to the shop that did the install thanks for the help guys
plyrh8r1
Member - Posts: 31
Posted: September 07, 2006 at 5:53 PM / IP Logged
well i took my car in to the alarm place and i found out that the 2nd and 3rd channel dont work anymore. so i have to get a new brain thnaks for the help guys
Monday, February 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
