07 santa fe, remote start
patmar
Copper - Posts: 69
Posted: August 22, 2006 at 8:25 PM / IP Logged
i everybody
i need infos for remote starter on santa fe 2007
thanks
pat
steiny83
Copper - Posts: 50
Posted: August 23, 2006 at 12:14 AM / IP Logged
What type of info? If you're looking for wiring diagrams, it looks like the newest Santa Fe listed on this website is 2003.
patmar
Copper - Posts: 69
Posted: August 24, 2006 at 6:47 PM / IP Logged
tach signal,doors locks arm disarm
swamprat323
Gold - Posts: 1,335
Posted: August 24, 2006 at 7:49 PM / IP Logged
#71919: 2007 HYUNDAI SANTA FE 4DR SUV WITH 2.7L ENGINE AND STANDARD AUDIO SYSTEM
     Security
     WIRE          COLOR          POLARITY          LOCATION
     Battery          RED          (+)          IGNITION SWITCH HARNESS
     Ignition 1          BLUE          (+)          IGNITION SWITCH HARNESS
     Starter 1          BLUE          (+)          IGNITION SWITCH HARNESS
     All Door Trigger          YELLOW          (-)          IN PLUG AT VEHICLE FUSEBOX
     Domelight Super          YELLOW          (-)          AT VEHICLE FUSE PANEL
     Trunk Trigger          BLACK/ ORANGE          (-)          IN HARNESS IN DRIVERS KICKPANEL
     Hood Trigger          PINK          (-)          AT VEHICLE FUSE PANEL
     Parking Lights          GREEN/ ORANGE          (+)          AT VEHICEL FUSE PANEL
     Convenience
     Headlights-Lo          GRAY/BLACK          (-)          IGNITION SWITCH HARNESS
     Wipers-Lo          WHITE          (-)          IGNITION SWITCH HARNESS
     Wipers-Hi          ORANGE          (-)          IGNITION SWITCH HARNESS
     Remote Start
     Ignition 2          PINK          (+)          IGNITION SWITCH HARNESS
     Accessory 1          GREEN          (+)          IGNITION SWITCH HARNESS
     Tachometer          BLUE/ORANGE          (AC)          AT IGNITION COIL
     Speed Sense          BROWN          (AC)          AT DIAGNOSTIC CONNECTOR UNDER DASH
     Brake Lights          GREEN/ BLACK          (+)          AT SWITCH ABOVE BRAKE PEDAL
     Reverse Lights          ORANGE          (+)          IN HARNESS AT LIGHT
     Horn          BROWN          (-)          IGNITION SWITCH HARNESS
     Modules
     WIRE          LOCATION
     Please select another category
     Doorlocks/Windows
     Power Unlock          WHITE/ BLACK          (-)          IN HARNESS IN DRIVERS KICKPANEL
     PowerLock          YELLOW          (-)          IN HARNESS IN DRIVERS KICKPANEL
     Driver Mtr Unlock          WHITE          (REV)          AT MOTOR IN DOOR
     Driver Mtr Lock          GRAY          (REV)          AT MOTOR IN DOOR
     LF Window Up          BLUE          (REV)          AT MOTOR IN DOOR
     LF Window Dn          BROWN          (REV)          AT MOTOR IN DOOR
     RF Window Up          GRAY          (REV)          AT MOTOR IN DOOR
     RF Window Dn          YELLOW          (REV)          AT MOTOR IN DOOR
     LR Window Up          RED          (REV)          AT MOTOR IN DOOR
     LR Window Dn          WHITE          (REV)          AT MOTOR IN DOOR
     RR Window Up          ORANGE          (REV)          AT MOTOR IN DOOR
     RR Window Dn          PINK          (REV)          AT MOTOR IN DOOR
     Sunroof Open          YELLOW/RED          (REV)          AT SUNROOF SWITCH
     Sunroof Close          YELLOW/BLACK          (REV)          AT SUNROOF SWITCH
Chris Luongo
Platinum - Posts: 3,746
Posted: August 25, 2006 at 12:49 AM / IP Logged
swamprat323, are you sure that's for a 2007?
All of the wires listed there match up with all of the 2006-and-older Santa Fes I've worked on.
The 2007 is all-new, and I believe includes a transponder key now..........I haven't had the opportunity to work on one yet, though.
swamprat323
Gold - Posts: 1,335
Posted: August 25, 2006 at 11:31 AM / IP Logged
i have not work on one either i just pulled that form code alarm data base. that waht came up for the 2007 year. but that not to say they (code) just copy the 2006 year. hope fulyl soem one eles post another company wire guide
patmar
Copper - Posts: 69
Posted: August 26, 2006 at 9:24 PM / IP Logged
thanks very much for help guys. i have installed remote tarter on 3 santa fe 2007 but not find the tach signal (i,m use the injector ) and for lock,unlock,arm,disarm use factory remote with rhy made by bypasskit. and for transponder bypss i'm use pku-hy (for tiburon 4cyl.). work great but if you have other infos send me
thanks
pat
larkster
Copper - Posts: 98
Posted: August 29, 2006 at 11:14 PM / IP Logged
I have done one,  I also used the injector for tach.  and for doorlocks i found in the driver kick panel grey/black and blue/black negative and alarm disarm pink/black in a white plug.
I have never heard of rhy by bypasskit.  I looked on the website and couldnt find it.  what exactly is it.  im curious
thanks
Larkster
patmar
Copper - Posts: 69
Posted: August 31, 2006 at 7:55 PM / IP Logged
thanks larkster
rhy is for use factory remote a small box 3 relays(lock unlock trunk or panic) inside and power supply (3v)for replace battery. very helpful for hyundai (only way to disarm and rearm is remote).I,m try to scan install sheet for you tomorow.
thanks again
pat
patmar
Copper - Posts: 69
Posted: September 19, 2006 at 6:59 PM / IP Logged
i larkster i'm find tach siganl and doors locks for santa fe 2007 . i'm try posting data sheet for rhy and diagram for doors locks . i don,t says how post in this site. i,m searching and come back with data sheet
thank you for help guys
pat
