GM Remotes
mexi
Copper - Posts: 156
Posted: August 31, 2006 at 11:13 PM / IP Logged
Anyone have a link on how to program GM factory remotes? Looking for info for a 2004 Impala keyless remote. Thanks
mexicang
Moderator - Posts: 12,488
Posted: August 31, 2006 at 11:28 PM / IP Logged
All the newer Impala's require the dealer scan tool to program the remotes.
mexi
Copper - Posts: 156
Posted: August 31, 2006 at 11:50 PM / IP Logged
Thank You for the info! Do you happen to know what year that started in?
mexicang
swamprat323
Gold - Posts: 1,335
Posted: September 01, 2006 at 3:38 PM / IP Logged
When no other working key for the car is available:
Type A      1. Put the newly cut Master key into the keyway and turn it to the ON (RUN) position. A "security" indicator
     light on the dashboard will stay on for 10 minutes.
     2. Within 1 minute after the indicator light goes off, turn the ignition to "OFF", then return to the ON (RUN)
     position. The indicator light again will stay on for 10 minutes (Do not remove the key.)
     3. Again, within 1 minute after the indicator light goes off, turn the ignition to "OFF", then return to the ON
     (RUN) position. The indicator light again will stay on for 10 minutes. (Do not remove the key.)
     4. When the light goes off the third time, the new key is programmed into the computer and will start
     the car. Remove the key and then re-insert it into the ignition lock and start the car.
     All previously stored codes will be erased. To stop the process at any time, simply remove the key and use
     an existing key to start the car.
For Cars where you want to just create a spare key:
     1. Place an already programmed key in the keyway
     2. Cycle the ignition from OFF to ON (RUN) to OFF.
     3. Within 15 seconds, insert the new, properly cut Transponder key in the ignition. Turn the key to ON
     (RUN) or START. The "security" indicator light will go on and off. Turn the key "OFF".
     4. The car will now start the car
     5. Repeat the second step for each new key to be programmed.
Chris Luongo
Platinum - Posts: 3,746
Posted: September 01, 2006 at 6:17 PM / IP Logged
But he wants to progrm a remote, not a key.
swamprat323
Gold - Posts: 1,335
Posted: September 01, 2006 at 6:50 PM / IP Logged
well we see honk on phonics did nto work for GM Remotes -- posted image.
auex
Platinum - Posts: 5,041
Posted: September 02, 2006 at 12:18 AM / IP Logged
It shows.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
