Warn away when remote started
oakey22
Member - Posts: 21
Posted: September 02, 2006 at 6:41 AM / IP Logged
i get the stand back warn away when i activate the remote start and the engine is running, it does this even when the system is not armed. Anyone know what it could be?
I have these sensors on the alarm
516U Vocalarm
DEI 508D Dual-Zone Sensor
Shock sensor and glass breakage.
Chris Luongo
Platinum - Posts: 3,746
Posted: September 02, 2006 at 10:19 AM / IP Logged
Is it a DEI remote starter as well?
The orange, ground-when-armed output is intended for the starter kill relay, as well as turning on the 508D and the 516U.
However, the orange wire is also active during remote start, as an anti-grind feature.........basically, if the remote starter is on, the starter kill is on too, so that you can't engage the starter again, if you mistakenly turn they key to "Start" when the remote starter is already on.
Go into programming, and switch to "anti-grind OFF," and see if that resolves the problem.
If that fixes it, but you would prefer to have your anti-grind working, I'm sure we can find a way to do that.
oakey22
Member - Posts: 21
Posted: September 02, 2006 at 2:53 PM / IP Logged
I did it, i made it turn off the voice module while the remote start is running.
Wednesday, February 18, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
