2005 Altima tach wire
jones100001
Member - Posts: 42
Posted: September 03, 2006 at 9:42 PM / IP Logged
Can I tap tach wire any other location besides ignition coil?  Preferably behind instrument cluster.
KarTuneMan
Platinum - Posts: 7,056
Posted: September 04, 2006 at 12:30 AM / IP Logged
behind the glove box.....WHITE/ green, @ the ECM.....
jones100001
Member - Posts: 42
Posted: September 04, 2006 at 1:01 PM / IP Logged
Can someone else comfirm this?  I did find GREEN / WHITE but not WHITE/ green
KarTuneMan
Posted: September 04, 2006 at 1:05 PM / IP Logged
Its actually UNDER the glove box, behind the heater motor. and theres also a white wire there that can be used as well. same location...
jones100001
Member - Posts: 42
Posted: September 04, 2006 at 1:12 PM / IP Logged
any white wire?  because I see bunch of plain white wires
KarTuneMan
Posted: September 04, 2006 at 10:44 PM / IP Logged
No, use the one that "tests" for tach....2005 Altima tach wire -- posted image.
thepencil
Gold - Posts: 1,526
Posted: September 05, 2006 at 9:27 AM / IP Logged
jones100001,kartuneman,
don't use the WHITE/ green tach at the ecm for this vechile. there was a service bulletine up that using the tach behind the glove box will cause the sevice engine light to come on. the warning did not come up on astroflex, but is indicated on directed. use the the non common injector wire instead. i have not seen it myself, but sometime it's better to advoid if the warning is there.
Be careful whose advice you buy, but be patient with those who supply it.2005 Altima tach wire -- posted image.
KarTuneMan
Posted: September 05, 2006 at 12:13 PM / IP Logged
Good to know, thanks pencil!
jack987
Posted: October 26, 2006 at 6:04 PM / IP Logged
Just cost me $62.00 at the dealer, to here him tell me that the "service engine soon" light was on due to the fact that someone had connected the remote starter to the the fuel injection. The code the Ecm was giving was P0174 - System to Lean: (Bank 2).
So my question now is where do I plug my tach wire so that the ecm doesn't freak out?
I don't want to pay $62.00 everytime that light comes on.
Mike M2
Platinum - Posts: 2,652
Posted: October 26, 2006 at 8:52 PM / IP Logged
Two of our biggest dealers we service are Nissan dealers. We've had tach issues on the dam things since i can remember. Funny, you'll use a coil wire on one and it works, get the same model car the next day and only a fuel injector will work. We finally went tachless on them all, had no problems since....
Mike M2
Tech Manager
CS Dealer Services
Monday, December 29, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
