Alarm suggestions for a 03 civic manual
grunge311
Member - Posts: 16
Posted: September 11, 2006 at 11:36 AM / IP Logged
Just like the topic says. I need an alarm for an 03 civic manual. I have done several prestige (audiovox) alarm/remote starts, and viper alarm/remote starts and love the features they have. but since this is a manual I don't need a remote start and would rather not deal with not the extra wires in a remote start system.
I would like it to be two way paging, and would like it to be cheap. Any suggestions for a 2way alarm w/o remote start?
Another question is, i have never used a microwave sensor before, do they work better than the shock sensor? should I (can I) use both?
Also this is the low end model civic (don't remember the letter designation dx, lx, ex) does it have the transponder system?
captainzab
Silver - Posts: 606
Posted: September 11, 2006 at 3:02 PM / IP Logged
I say get the Viper 5000, Python 900, or Clifford 10.5x
And buy a DEI microwave sensor. And all you do is plug it into the extra port that^^ alarm has.
Most likely it does have transponder. But that has NOTHING to do with regular alarm. (only remote start)
Seeing how you already did alarm/remote start install, should be easy to do alarm only.
Note: You Always Dont Get What You Pay For.
mobilecustoms
Silver - Posts: 397
Posted: September 11, 2006 at 3:14 PM / IP Logged
i like the dei led systems i think the 3000.
xtremej
Gold - Posts: 1,440
Posted: September 11, 2006 at 3:19 PM / IP Logged
Doubt it has the transponer key, look into these remote start/alarms the range is awesome.
Hornshockey
Silver - Posts: 520
Posted: September 11, 2006 at 9:34 PM / IP Logged
that car most likely does have a transponder; just look for the flashing green key on the gauge cluster when you put the key in and turn it on
however, if you're not doing a remote start system then the transponder issue is really moot.
Life moves pretty fast; if you don't stop and look around once in a while; you could miss it.
grunge311
Member - Posts: 16
Posted: September 12, 2006 at 4:01 PM / IP Logged
Thanks guys, I think I will look into the viper 3000, the price is right and it seems to have everything I want. I still don't know how I would hook up a shock sensor and a microwave sensor. will it have two ports? any ideas?
captainzab
Silver - Posts: 606
Posted: September 12, 2006 at 4:11 PM / IP Logged
viper 3000 has 2 extra ports for additional sensors.
all you do is plug it up
grunge311
Member - Posts: 16
Posted: September 13, 2006 at 8:11 AM / IP Logged
I just ordered an autopage 420lcd. I have heard good things about autopage and it also has dual ports.
I am ordering a dei 508d field disturbance sensor for it right now.
