Prostart CT-5000 Need Manual
labradorian70
Posted: September 17, 2006 at 11:30 PM / IP Logged
DOes anyone know where I can find a instalation manual for the Prostart CT-5000 in PDF format
Info on the back   CT-5000 Date:2005-11-10 V.H4.2 F4.0B
I bought this at canadian Tire last spring and going to install soon and noticed the manual is not in the box.
GLen
Labradorian
swamprat323
Gold - Posts: 1,335
Posted: September 17, 2006 at 11:41 PM / IP Logged
is prostart the company that makes it or is it the series of a make. prostart sounds familer, but cant put my mind on it
thepencil
Gold - Posts: 1,526
Posted: September 18, 2006 at 12:25 PM / IP Logged
Autostart makes them.
You can go to autostart.ca and look through the different model and see which one of the model matches yours. Wiring color have stay the same for years, but that doesn't mean anything if you are not familiar with this brand. You might be better of getting the correct wiring diagram for the unit if you have not use Autostart product before.
Be careful whose advice you buy, but be patient with those who supply it.Prostart CT-5000 Need Manual -- posted image.
ck auto
Copper - Posts: 257
Posted: September 21, 2006 at 10:07 PM / IP Logged
hi go to www.prostart.org download manual there for remote program push hood pin down while parklight on push and release hood pin again then turn key on off 3 times press lock 2 times
good luck
kirk
Sunday, February 22, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
