2000 maxima remote start
zshopa
Member - Posts: 10
Posted: September 19, 2006 at 9:50 PM / IP Logged
hello everyone,
i am currently installing a remote starter/ alarm into my 2000 nissan maxima, so far everything is connected.  everything works except the remote start function, i think my problem may be that im not connecting the bypass module correctly. ive never installed one like this and dont know how to apply that ring from the 556u, what happens is i press the start button on the remote, the car seems to go to ACC/ON and then it clicks off in about 1 -2 seconds no cranking begins. please let me know what possible solutions i can try or anything. i appreciate any help.
Thank you,
DAve
Twelvoltz
Platinum - Posts: 2,384
Posted: September 19, 2006 at 10:24 PM / IP Logged
To verify that the problem is with your transponder bypass, simply leave a working key in the vehicle's ignition in the off position and try to remote start the vehicle. If the vehicle starts and runs then you know the bypass is where your problem lies. If the car does not start up and run then you will need to recheck your wiring at the ignition.
Hope this helps.
Platinum - Posts: 12,488
Posted: September 19, 2006 at 10:28 PM / IP Logged
Dave, have you also checked to see if the STARTER output is infact sending a 12 volt signal to the starter wire that you have ? Make sure that you didn't wire the starter disable relay backwards.
zshopa
Member - Posts: 10
Posted: September 19, 2006 at 10:47 PM / IP Logged
ok so i tried it with the key in the off position and it did not work, now the model i have is Ultrastart 1270TL  any possible things that i may have missed?
Chris Luongo
Platinum - Posts: 3,746
Posted: September 19, 2006 at 11:53 PM / IP Logged
--Even if the transponder bypass is wrong, Nissans will still crank; they just won't start.
--If you have any doubts at all about the bypass, simply unplug it, stick a key in the ignition, and try to remote-start the car.
--Have you powered up both starter wires in the Nissan?
dcman41
Copper - Posts: 211
Posted: September 20, 2006 at 12:07 AM / IP Logged
You need too hook up both starters. Also make sure your starter wires arn't backwards if you did a starter kill/antigrind.
zshopa
Member - Posts: 10
Posted: September 20, 2006 at 4:34 PM / IP Logged
ok im gonna try and reverse the starter wires i may have them backwars
xtremej
Gold - Posts: 1,440
Posted: September 20, 2006 at 5:10 PM / IP Logged
Just fyi the 1270tl is just a remote start not an alarm.....
zshopa
Member - Posts: 10
Posted: September 20, 2006 at 5:12 PM / IP Logged
i tried to switch the starter wires, but im not getting any different results
and i tried unplugging both starter wires and got the same result.....  i dont know where i went wrong with this i never had this problem on my accord, is there anything i need to do different on the maxima?
xtremej
Gold - Posts: 1,440
Posted: September 20, 2006 at 5:32 PM / IP Logged
Try this run your start directly from the remote start BLACK/ dark red I believe this is the primary start wire  the BLACK/ blue is for cold start up, but for testing try the blk/ dark rd. Have you learned the tach before trying to remote start?
Page of 3
