06 nissan altima, door locks, data buss
swamprat323
Gold - Posts: 1,335
Posted: September 23, 2006 at 7:59 PM / IP Logged
is this car on a data buss for door locks etc, im hearing both yes and no on the matter.
KarTuneMan
Platinum - Posts: 7,056
Posted: September 23, 2006 at 8:08 PM / IP Logged
Based off of what I have for tech support.....BOTH. Wiremagic says use the CAN SL. Astrochart shows goin into the doors.
Chris Luongo
Platinum - Posts: 3,746
Posted: September 24, 2006 at 9:05 AM / IP Logged
It depends.
--If it has a factory alarm system, and BOTH front windows have the auto-down feature, it is a data system.
The key cylinder in the exterior of the front door sends ground signals to the power window switch, and then the window switch communicates to the body-control module via data.
In this case, you have three choices as to how you're going to control the locks:
1. Run wires into the door.
2. Buy a doorlock module from bypasskit.com.
3. Go to the carsound.com security forum, do a search for "nissan bcm," and you will learn a special trick.
--If it has no factory alarm, and ONLY one auto-down window, it is different. The regular lock and unlock wires run directly from the door to the BCM, and you can easily get them at the BCM, with no extra special parts.
swamprat323
Gold - Posts: 1,335
Posted: September 24, 2006 at 11:00 PM / IP Logged
thanks for that info
Wednesday, April 22, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
