cs2016dpfm
hurricanetech
Member - Posts: 13
Posted: September 30, 2006 at 11:51 AM / IP Logged
I am planning out the installation of a CS2016DPFM remote start alarm system on my 2000 Jeep Cherokee and I notice as I was going through the wiring instruction there is a wire for OEM Disarm output.  As almost all of you know this will disable the factory anti-theft system.  Now I also have a OAF-20 module, this is supposed to be the transponder unit to bypass the Anti-theft system. This sounds like the same thing as the disarm wire, but I don't know if i should or can connect both, or one or the other.
Hurricane
KarTuneMan
Platinum - Posts: 7,056
Posted: September 30, 2006 at 12:03 PM / IP Logged
The transponder bypass does NOT controll the factory security. This simulates a key in the ignition.
 FACTORY DISARM Purple / YELLOW In driver's kickpanel   -
Trigger this wire with the output from your CS unit. "factory disarm" You need to "do" both!
hurricanetech
Member - Posts: 13
Posted: September 30, 2006 at 12:28 PM / IP Logged
The only other thing that I am curious about is the doom light wire. Location/color?
Hurricane
KarTuneMan
Posted: September 30, 2006 at 2:49 PM / IP Logged
In a gray 2 pin connectoer drivers kick Yellow wire Neg(-) trigger
hurricanetech
Member - Posts: 13
Posted: September 30, 2006 at 3:10 PM / IP Logged
I appreciate it, but I think the wiring chart needs to be updated. I'll keep on top of it and let ya know.
Hurricane
hurricanetech
Member - Posts: 13
Posted: October 01, 2006 at 11:28 AM / IP Logged
One other thing this alarm supports positive and negitive door lock triggers.  They provide diodes for this. The jeep that I am working on is negitive trigger and i don't think i need to use relays.  Does this seem right?
Hurricane
KarTuneMan
Posted: October 01, 2006 at 4:31 PM / IP Logged
KarTuneMan
Posted: October 01, 2006 at 4:44 PM / IP Logged
Your door locks are NEG(-) if you have built in relays wire them for negative.
hurricanetech
Member - Posts: 13
Posted: October 03, 2006 at 2:14 PM / IP Logged
You are the man, THX
Hurricane
