Power trunk solenoid
oakley2000sel
Member - Posts: 33
Posted: October 07, 2006 at 12:59 PM / IP Logged
Car starter is up and running. I installed a power trunk solenoid, grounded at the trunk and power cable running to the front with a switch. Works like a charm. Installed a Crimestopper alarm/starter, and since it gives a - output for trunk I hooked up the relay as stated on this site. Problem: I push the power trunk button on the remote, I hear the relay click and test if there is a positive current coming out of the wire that connects to the trunk wire and there is but the trunk does not open? Still works with the switch no problem. Any ideas?
Mike M2
Platinum - Posts: 2,652
Posted: October 07, 2006 at 1:48 PM / IP Logged
Lets see, 12 volts to 30 and 85, 86 from your output of your alarm, 87 to the trunk solenoid, right?
Mike M2
Tech Manager
CS Dealer Services
meh66
Copper - Posts: 266
Posted: October 09, 2006 at 8:40 AM / IP Logged
Most after market trunk poppers need to see + 12 volts to move the actuator. The trigger on your Crime stopper is negative (-) and the current is low. So you need to add a relay and connect it in the following procedure:
86 - (-) trigger from Crime Stopper Alarm
85, 87 - (+) 12 volts
30 - To trunk release switch or solenoid (+)
MEH66
"Car Performance and Mobile Electronic Enthusiats"
meh66
Copper - Posts: 266
Posted: October 09, 2006 at 8:41 AM / IP Logged
MEH66
oakley2000sel
Member - Posts: 33
Posted: October 09, 2006 at 10:23 AM / IP Logged
ok guys, thanks for all your help! You're gonna laugh. There was a diode taped into the wire harness for the relay not letting the power get to the trunk wire. I kept testing the connection on the plug but it was before the diode. I cut it out and POP! So thanks again for the info! Love the alarm/starter.
