03 Murano Tach wire?
techfiftyfive
Copper - Posts: 46
Posted: October 08, 2006 at 5:48 PM / IP Logged
I read somewhere here that I could find it in the passenger side kick, labeled as a yellow wire. Im unable to remove the paneling on that side and I dont want to risk damaging anything neither. I want to go behind the gauges to get the signal, but does anyone know how to remove the gauges on these cars? Or remove the paneling on the passenger side? Thanks in advance.
KarTuneMan
Platinum - Posts: 7,056
Posted: October 08, 2006 at 11:12 PM / IP Logged
@ the pcm behind the glove box. white, or yellow....pick one!
techfiftyfive
Copper - Posts: 46
Posted: October 09, 2006 at 5:05 PM / IP Logged
Any tips on getting around back there? I tried removing the 4 screws at the very bottom of the glove, and I also removed the passenger side air vent, but still had no luck. I tried testing the yellow wire that I could see, but it wasnt giving me the correct reading.  In order to remove the glove, is it the same as like the Honda's? Push the sides of it, inwards then drop down?
Mike M2
Platinum - Posts: 2,652
Posted: October 15, 2006 at 9:12 PM / IP Logged
I always go under the hood for tach...
Tachometer NOT red or black  ac  any ignition coil or fuel injector
Mike M2
Tech Manager
CS Dealer Services
techfiftyfive
Copper - Posts: 46
Posted: October 16, 2006 at 4:13 AM / IP Logged
I normally go behind the gauge cluster cause Im not really familiar with stuff underneath the hood. I read somewhere that the wire under the hood was yellow, and I found a yellow one, tested it, I could've sworn my meter was reading it as if it was the tach wire, but I was unable to program it. Went back to that yellow wire, my meter probably read it right, but my eyes read it wrong cause the 2nd time I metered it, it read 60.XX something.
Friday, February 6, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
