By-passing stock alarm problem.
gvonne
Posted: January 21, 2003 at 12:56 PM / IP Logged
I have a 98 Subaru Legacy Outback with a stock alarm (door locks, starter kill flashing lights etc...) and it needs to be replaced bad.  I know where the module is but I am not sure if I just unplug this thing or cut and try to use the existing wires it uses (if that will even work that is).  At the least I would need a wiring diagram for the stock alarm.  I all ready have one for the wires in the car itself but not for the alarm.  If anybody got any tips for me it would be GREATLY appreciated.  Thanks.
10nesne1
Silver - Posts: 284
Posted: January 21, 2003 at 1:12 PM / IP Logged
You can connect wires to it, but you will have to test all the wires.  Most of the wires, that I would use from the stock alarm system are door pin, door locks, and ignition wires.
Subaru
Legacy Outback
1996-1999
Remote Starter  Wiring Colors and Notes
Function
Vehicle  Color
Location
Start:
BLUE/RED
IGNITION SWITCH HARNESS
Ignition  #1:
RED
Ignition #2:
RED / YELLOW
IGNITION SWITCH HARNESS *
Ignition  #3:
N/A
Accessory:
N/A
Brake  Light:
WHITE/ BLACK
AT SWITCH ABOVE BRAKE PEDAL
Tach  Signal:
YELLOW/BLUE
AT IGNITER **
Parking Lights:
BLACK/ GREEN (-)
AT HEADLIGHT SWITCH
Headlights:
BLUE/BLACK (-)
AT HEADLIGHT SWITCH
OEM Alarm  Disarm:
WHITE/ GREEN (-)
AT SECURITY MODULE BEHIND GLOVE BOX
OEM Alarm  Arm:
Diesel  Glow Plug:
Clutch  Bypass Wire:
Notes:
 * Ignition 2 must be programmed to not be "Hot" during crank or a "Check Engine" light will appear in the instrument cluster. ** Ignitor is located at center rear of engine compartment.
Subaru
Legacy Outback
1996-1999
Alarm and Keyless  Entry Wiring Colors and Notes
Function
Vehicle  Color
Location
Constant  +12 Volts:
BLACK / YELLOW
Starter  Kill:
BLUE/RED
Ignition  +12 Volts:
RED
Dome  Lights/Superv:
RED / WHITE (-)
AT DOME LIGHT OR COMB. METER
OEM Horn:
RED / GREEN (-)
STEERING COLUMN HARNESS
Power  Lock:
WHITE/ RED (-)
AT TIMER MOD. BEHIND RT. SIDE DASH ***
Power  Unlock:
WHITE (-)
Trunk  Release:
N/A
Alarm  Input Wire:
RED / WHITE (-)
Notes:
*** See Note #201 Negative Pulse Door Lock Diagram
gvonne
Posted: January 22, 2003 at 4:25 PM / IP Logged
Whoooooh. Thanks 10nesne 1!!  That is exactly what I needed!
Wednesday, December 31, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
