Security light, 2001 Olds Alero
paddyboy
Posted: October 25, 2006 at 7:31 AM / IP Logged
I have a 2001 Olds Alero.  I recently lost my key and had to drill out the ignition lock.  I was successful at my attempt and was able to remove the ignition lock.  I purchased  a new one at Chevrolet.  I brought them my title and reg and they retrieved the vehicle key code and cut me 2 new keys.  I took the keys and lock to a reputable locksmith due to time restraint as suggested by parts person.  The lock was coded to the keys and I then installed the new lock and reassembled everything.  The car starts and runs fine but I have a steady security light.  Is there an easy solution and if not, I'll take any information available.
Take nothing but photographs, leave nothing but footprints
sparkie
Platinum - Posts: 2,061
Posted: October 25, 2006 at 3:11 PM / IP Logged
Your car has Passlock II. It is an immobilizer system built into the key/ignition cylinder/switch. It is separate from your key cylinder, but is a a part of the ignition barrel. It has three wires attached to it. Usually black, white and yellow. You may have damaged it in the process. I would suggest that you find a dealer or knowledgable mechanic that can repair it for you. There are many possibilities of what could have happened.
sparky
paddyboy
Posted: October 25, 2006 at 4:23 PM / IP Logged
Ok, thanks much!
