2000 Ford F350 RKE
shenders99
Posted: October 28, 2006 at 8:34 AM / IP Logged
So I am stumped and the guys at FTE recommended I try picking your brain.
I have installed a Crimestopper RS900VII in the said truck. Remote start works fine, but I can't get the door locks to work properly, or at all for that matter.
First off, I can't get a firm word on whether the door lock system is positive, negative or reverse polarity. (The truck has factory keyless entry with out the fat key for the anti-theft). I have tried the positive wiring and just today the reverse polarity with relays and nothing has worked.
I did not hook up the OEM disable as I did not think that it was neccesary. I was also unable to find the DkGREEN/ Purple wire that wiring magic claims is the OEM disable wire in the drivers side kick panel.
The wires in the kick panel that I am using are
door lock - Pink / YELLOW tracer
door unlock - Pink/Light green tracer
Can anyone help me with this...
Thanks in Advance!
kgerry
Platinum - Posts: 3,455
Posted: October 28, 2006 at 9:45 AM / IP Logged
what happens when you meter those wires?    you should be able to determine what they are by metering them....
my info shows them as negative on most models, 5 wire on base model
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
xtremej
Gold - Posts: 1,440
Posted: October 28, 2006 at 10:48 AM / IP Logged
According to dei the wires are located in a gray molex plug to the right of the steering column, the should be negative trigger and pink / YELLOW and pink/lt.green. If you didn't have factory keyless they would be 5 wire hook up.
shenders99
Posted: October 28, 2006 at 10:55 AM / IP Logged
Crimestopper believes them to be negative to, but that did not work.
Wire #1 - 12V on unlock
Wire #2 - 12V on lock
In that scenario I should just splice into the wires, but that did not work...
xtremej
Gold - Posts: 1,440
Posted: October 28, 2006 at 11:06 AM / IP Logged
Have yoy metered the wires to confirm their polarity?
shenders99
Posted: October 28, 2006 at 11:33 AM / IP Logged
No, I am not sure how to do that. I have a dmm but am not that well trained on it. It is a digital unit if you help me.
Also, if the rke unit is set up for negative then how can I test those posts to make sure they are working and that the unit is not the issue.
xtremej
Gold - Posts: 1,440
Posted: October 28, 2006 at 11:38 AM / IP Logged
I would test the vehicle first. What voltage settings does your dmm have?
shenders99
Posted: October 28, 2006 at 11:48 AM / IP Logged
voltage settings 200v, 20v, 2000m, 200m and all the others. It is a nice digital one.
When I test the vehicle I get
Wire #1 - 12v unlock, .3v lock
Wire #2 - 12v lock, .3v unlock
Some one told me this is reverse polarity once, but who know at this point.
xtremej
Gold - Posts: 1,440
Posted: October 28, 2006 at 12:47 PM / IP Logged
OK use the 20 volt setting. What is the reading without hitting the switch? Then hit the switch if it drops to near 0 then they are negative trigger.
shenders99
Posted: October 28, 2006 at 1:13 PM / IP Logged
Got it, hooked up, working, all good.
It was operator error. I was using the wrong tow pink / YELLOW, pink/ltgreen wires.
Thanks Guys...
Sunday, January 11, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
