2002 mitsubishi lancer, alarm
sheldondron
Posted: October 29, 2006 at 4:28 PM / IP Logged
yeah i bought a clifford martix rs3.5 and i need a wiring diagran for it i have a mit. lancer 4 dr. 2002. thanks
KarTuneMan
Platinum - Posts: 7,056
Posted: October 29, 2006 at 5:33 PM / IP Logged
 MODEL YEAR(S)
 LANCER  2002 -
 KEY T-HARNESS IMMOBILIZER
  N/A   N/A   N/A
 PART  COLOR LOCATION
 12 VOLT CONSTANT  WHITE (+)   IGNITION SWITCH HARNESS
 STARTER BLACK / YELLOW (+)  IGNITION SWITCH HARNESS
 STARTER 2 N/A
 IGNITION 1 BLACK/ WHITE (+) IGNITION SWITCH HARNESS
 IGNITION 2 N/A
 IGNITION 3 N/A
 ACCESSORY /HEATER BLOWER 1 BLUE/BLACK (+)  IGNITION SWITCH HARNESS
 ACCESSORY /HEATER BLOWER 2 N/A
 KEYSENSE N/A
 PARKING LIGHTS ( - ) N/A
 PARKING LIGHTS ( + ) GREEN/ YELLOW (+) and GREEN / WHITE (+) Use BOTH, See NOTE *1  IN WHITE PLUG, AT BOTTOM OF FUSEBOX
 POWER LOCK PURPLE (TYPE B)  @ DRIVERS DOOR HARNESS
 POWER UNLOCK LIGHT GREEN (TYPE B)  @ DRIVERS DOOR HARNESS
 DOOR TRIGGER WHITE (-)  IN WHITE PLUG, AT THE BOTTOM OF FUSEBOX
 DOMELIGHT SUPERVISION USE DOOR TRIGGER, Requires Part #775 Relay
 TRUNK RELEASE N/A
 SLIDING POWER DOOR N/A
 HORN YELLOW (-)  @ STEERING COLUMN HARNESS
 TACH BLACK / YELLOW or BLACK/ GREEN  @ COIL PACK
 WAIT TO START LIGHT N/A
 BRAKE GREEN (+)  @ SWITCH ABOVE BRAKE PEDAL
 FACTORY ALARM DISARM  GRAY (-)  @ DRIVERS DOOR HARNESS
 ANTI-THEFT N/A
 EXTRA INFORMATION
NOTE *1 this vehicle has 2 wires for the PARKING LIGHT Circuit, to connect it will require 2 extra Relays part #775, to connect, See DIAGRAM
http://64.85.6.129/extrainfo/diagrams/15579_LANCER_DUAL%20PARKING%20LIGHT%20DIAGRAM.pdf
Monday, May 4, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
