04 Silverado Sport side
magicmanwv
Member - Posts: 13
Posted: November 11, 2006 at 7:41 PM / IP Logged
 I am installing a Viper 560XV with a 457G GM Data bus interface first I know there are a lot of wires that are not used but I would like to use the neutral safety switch where can I hook it up? All so is it possible to get each the driver’s door to unlock then the passenger door with a second push of the remote? The 560XV says on the door lock harness green (-) lock (+) unlock, blue (+) lock (-) unlock do I hook them to the 457G green to light green and blue to blue and what gets hook to the blue/white wire on the 457G? Thanks for any help I'm use to older cars before databus :)
Twelvoltz
Platinum - Posts: 2,384
Posted: November 11, 2006 at 8:33 PM / IP Logged
The neutral safety wire is not required on the 04 Silverado, as your truck will not start in gear. Just ground the h/3 BLACK/ white.
Yes, you can get driver's door priority unlocking with the 560xv.
Unlock Motor      tan       5wi      driver door module in door
You would use the main unlock negative output to 5wire this wire, use the light blue h2/1 for the unlock output and the main lock wire negative to the 457G, ignoring the + output status of these wires.
There are a couple of wires on the 560xv that are labeled as 'status output'. Any of these can be hooked to the blue/white on the 457.
magicmanwv
Member - Posts: 13
Posted: November 11, 2006 at 8:53 PM / IP Logged
Thanks! just what I was looking for....
magicmanwv
Member - Posts: 13
Posted: November 12, 2006 at 4:34 PM / IP Logged
 I am installing a Viper 560XV with a 457G GM Data bus interface The lites flash during remote start my guess is I'm going to have to power the 2 aux wire(brown) to get them to say on. here is a problem the doors will not lock when I hit the lock/arm button the doors unlock same with the unlock/disarm and the door trigger works when the door is closed not open? might just be the shock sensor but weard never the less. Blue 457 to blue door lock harness on the 560, light green 457 to green door lock harness on the 560, Green 457 to H1/5 green on the 560 Help and yes I tried to flip the green wires around Everything else works remote start, shock sensor, hood pin, help.
JWorm
Platinum - Posts: 2,208
Posted: November 12, 2006 at 4:53 PM / IP Logged
What did you connect the grey/black of the 457G to?
You need to program parking light flash to constant on the Viper 560. The default setting is flashing. Not powering the brown acc 2 has nothing to do with it.
magicmanwv
Member - Posts: 13
Posted: November 12, 2006 at 5:06 PM / IP Logged
The park lites are fine its getting dark here so the head lights are trying to come on. Nothing on gray/black
JWorm
Posted: November 12, 2006 at 5:18 PM / IP Logged
Go into programming and change the parking lights output to constant. Your headlights will stop flashing.
The grey/black needs to go to the grey/black wire that leads to the domelight in the truck. You can find it in the drivers A-Pillar. If there is an underdash light, you can also get it there.
magicmanwv
Member - Posts: 13
Posted: November 12, 2006 at 5:26 PM / IP Logged
Ok I will try that Thanks
magicmanwv
Member - Posts: 13
Posted: November 12, 2006 at 6:19 PM / IP Logged
 Ok I hooked up the the gray/black no change the unit will not go into program mode nor will it learn the tach
magicmanwv
Member - Posts: 13
Posted: November 12, 2006 at 7:01 PM / IP Logged
 Ok I have ck'ed everything this truck has had a viper in it before I think it has been a stolen recovery the door chimes have never worked and the speakers have a short in them I pulled the radio to ck it and it has $600 wrote on it and a check mark do you think that the radio might be the problem? also the doors try to unlock when you turn on the headlights. Help
Thursday, April 23, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
