04 Dodge Ram Diesel
leasnit
Member - Posts: 7
Posted: November 14, 2006 at 1:34 AM / IP Logged
Its been a couple years since Ive put one of these in and maybe im missing something...
Installed a 551R in a 04 Ram Diesel today and for some reason after its been remoted started for about 10 seconds, it loses first and 2nd ignition... the ground is solid... I thought it might have been the pulse timer shutting it down, but that wasnt the case.. Does anyone have any ideas? Im about fresh out of them.....
qdaddy
Copper - Posts: 133
Posted: November 14, 2006 at 1:46 AM / IP Logged
did you get a tach has been learned confirmation LED will go solid when succesful tach has been learned try it with hoodpin disconnected and brake disconnected ground thin BLACK/ white04 Dodge Ram Diesel -- posted image.
leasnit
Member - Posts: 7
Posted: November 14, 2006 at 1:50 AM / IP Logged
It's setup for voltage, couldnt find the tach wire at the ECU.. tried it without the brake wire, and blk/wht is grounded...
qdaddy
Copper - Posts: 133
Posted: November 14, 2006 at 1:58 AM / IP Logged
tach at ecm lower side engine 60 pin plug pin 24 may also be at cam sensor left of ecm 3 pin plug  dark blue/gray tach always works best on dei products04 Dodge Ram Diesel -- posted image.
leasnit
Member - Posts: 7
Posted: November 14, 2006 at 2:04 AM / IP Logged
I know it does, but thats not explaining why the ignition is shutting down after 10 seconds of it running already...
I thought I had blue/grey but it wouldnt program.. I thought it said something about tach on diesels being grey/blk but all I could find was grey..
qdaddy
Copper - Posts: 133
Posted: November 14, 2006 at 2:14 AM / IP Logged
if 03 thengray/black in blk plug at pcm
04 then as stated before make sure of year in door jam sticker use a digital multi meter(dmm) set to ac volts ground your neg lead test with red lead with truck on should 3-6 volts ac04 Dodge Ram Diesel -- posted image.
qdaddy
Copper - Posts: 133
Posted: November 14, 2006 at 2:16 AM / IP Logged
starts and stops is what happens when cant read voltage or tach properly make sure you change your menu settings to tach and may adjust threshlod to low or high 04 Dodge Ram Diesel -- posted image.
KarTuneMan
Platinum - Posts: 7,056
Posted: November 14, 2006 at 8:16 AM / IP Logged
switch you ignition outputs. (turn on ign.2 before ign. 1) just try it.
leasnit
Member - Posts: 7
Posted: November 14, 2006 at 11:10 AM / IP Logged
Cool man I'll try that later.. thanks...
KarTuneMan
Posted: November 14, 2006 at 11:36 AM / IP Logged
I have NO IDEA why this would be a solution to your problem...but in the astrochart this is how THEY say to energize the ignitions
