2006 Hyundai Tiburon alarm/rs
forbidden
Platinum - Posts: 5,354
Posted: November 17, 2006 at 4:58 PM / IP Logged
Need some info for this vehicle please. So far the locking system is being a real PITA.
Mike M2
Platinum - Posts: 2,652
Posted: November 17, 2006 at 5:59 PM / IP Logged
12voltsred (x2)(common 30A) + ignition harness
Starterwhite + ignition harness
Second StarterN/A
Ignitionred + ignition harness
Second IgnitionN/A
Third IgnitionN/A
Accessorypink + ignition harness
Second Accessoryorange + ignition harness
Keysenseblue/orange - ignition harness
Power Lockyellow or blue F BCM, 12 pin plug, pin 8 or 3
Notes: The yellow wire will test when moving the driver lock knob, the blue wire will test when moving the passenger lock knob.
The BCM (Body Control Module) is part of the fuse/relay box under the driver side dash.
Power Unlocksame as power lock wire
Lock Motorgreen 5wi BCM, 22 pin plug, pin 6
Notes: The BCM (Body Control Module) is part of the fuse/relay box under the driver side dash.
Unlock MotorGREEN/ black 5wi BCM, 22 pin plug, pin 8
Parking Lights+pink/black (L), GREEN/ org (R) + BCM, 22 pin plug, pins 10 and 5
Parking Lights-blue/orange - headlight switch
Hazardswhite - hazard switch
Turn Signal(L)RED / orange + BCM, 22 pin plug, pin 13
Turn Signal(R)orange + BCM, 22 pin plug, pin 17
Reverse Lightgray + BCM, 22 pin plug, pin 2
Door Triggeryellow - BCM, 22 pin plug, pin 11
The individual door trigger wires are also at the BCM in a 12 pin plug. The driver door is gray/black in pin 9. The passenger door is gray in pin 4. Use both wires and diode isolate each.
Dome Supervisionyellow - BCM, 8 pin plug, pin 3
Trunk/Hatch PinGREEN/ black - BCM, 12 pin plug, pin 6
Hood PinGREEN/ orange - BCM, rear 20 pin plug, pin 9
Trunk/Hatch Releaseblue + driver kick, harness to rear
Power Sliding DoorN/A
Factory Alarm Armfactory remote only
Factory Alarm Disarmfactory remote only
Disarm No Unlockwith ign, acc, and key sense
Tachometerwhite ac passenger kick, 23 pin plug, pin 4
Wait to startN/A
Brake Wirewhite + brake pedal switch
Parking Brakeblue/black - driver kick, 18 pin plug, pin 2
Horn TriggerGREEN/ black - horn switch
Memory Seat 1N/A
Memory Seat 2N/A
Memory Seat 3N/A
2006 Hyundai Tiburon alarm/rs -- posted image.
Interface Module:Category:
Immobilizer Bypass
Required:
Yes
Type:
Transponder
Part #: OM-Hyundai-1
Alternate Part1 #: 556UW
Mike M2
Tech Manager
CS Dealer Services
KarTuneMan
Platinum - Posts: 7,056
Posted: November 18, 2006 at 4:46 AM / IP Logged
LOCK Yellow In harness from driver's door   -
 This is a 1-wire doorlock system. Ground the wire to unlock the doors, and open the wire to lock them. See the doorlock diagram for exact wiring instructions.
 UNLOCK Yellow In harness from driver's door   -
break the lock/unlock wire with a relay using pins 87a and 30. take the lock output  to pin 85, 12v to pin 86. unlock output to the inside (closest to the alarm brain) of the broken lock/unlock wire. (before the relay)
forbidden
Posted: November 18, 2006 at 7:13 AM / IP Logged
Found the wires, they were green and GREEN/ black 5 wire reverse polarity on the BCM. Clutch bypass was simple, it is a positive bypass.
KarTuneMan
Posted: November 18, 2006 at 12:51 PM / IP Logged
If you have the choice of going to the lock motor itself, and wiring up for a 5 wire conection (times 2) or going to one wire, using 1 relay....wouldn't you take the easy way out. I'm just curious, cause alot of the tech info gives you 2 choices for lock/unlock.
Friday, May 22, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
