01 mitsubishi Montero
pitoaudiovisual
Copper - Posts: 388
Posted: December 10, 2006 at 8:47 PM / IP Logged
Can anyone tell me if there is a difference in wiring from an 01 mitsubishi montero and 01 mitsubishi montero sport because if there is i need the paper work to both cause i dont know which one im doing and i want to be ready for either one.. Thank you in advance..
Confidence is the key to any project!!
Twelvoltz
Platinum - Posts: 2,384
Posted: December 10, 2006 at 9:29 PM / IP Logged
They are different:
01 Montero:
DIRECTWIRE™ WIRING INFORMATION - MITSUBISHI / MONTERO / 2001 / Remote Start
[PRINT THIS PAGE]
12volts      blue/white       +       ignition harness
Starter      BLACK / YELLOW       +       ignition harness
Second Starter
Ignition      blue/black       +       ignition harness
Second Ignition
Third Ignition
Accessory      blue/red       +       ignition harness
Second Accessory      blue / YELLOW       +       ignition harness
Keysense
Power Lock      lt. GREEN/ red       -       ETACS ECU
Notes: The ETACS (Electronic Timer Alarm Control System) ECU is under the driver side dash, attached to the fuse box.
Power Unlock      BROWN / white       -       ETACS ECU
Lock Motor      blue/black             fuse box
Unlock Motor      blue/red             fuse box
Parking Lights+      GREEN / WHITE             driver kick panel
Parking Lights-
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger      RED / green       -       ETACS ECU
Dome Supervision      use door trigger
Trunk/Hatch Pin      tied in with doors
Hood Pin      blue/black       -       ETACS ECU
Trunk/Hatch Release
Power Sliding Door
Factory Alarm Arm      blue       -       driver door harness
Notes: These wires will also lock and unlock the doors. Unlock requires a double pulse.
Factory Alarm Disarm      brown       -       driver door harness
Disarm No Unlock
Tachometer      yellow             inspection connector
Notes: The inspection connector is on the driver side of the engine compartment behind the relay box.
Wait to start
Brake Wire      blue/orange       +       brake pedal switch
Parking Brake
Horn Trigger      lt GREEN/ black       -       steering column
Memory Seat 1
Memory Seat 2
Memory Seat 3
Interface Module:      Category:
Immobilizer Bypass      Required:
Yes      Type:
Transponder
Part #: 556UW
Alternate Part1 #: DesignTech 20402
Alternate Part2 #: DesignTech 29402
Notes:
Smart Starter Kill Relays: Not Available
warning
Directed Electronics assumes no responsibility with regards to the accuracy or currency of this information. Proper installation in every case is and remains the responsibility of the installer. DEI assumes no liability or responsibility resulting from improper installation, even in reliance upon this information.
01 Montero Sport:
DIRECTWIRE™ WIRING INFORMATION - MITSUBISHI / MONTERO SPORT / 2001 / Remote Start
[PRINT THIS PAGE]
12volts      white       +       ignition harness
Starter      blk/yel or blk/blu       +       ignition harness
Second Starter
Ignition      BLACK/ white       +       ignition harness
Second Ignition
Third Ignition
Second Accessory      blue       +       ignition harness
Keysense
Power Lock      BLACK/ red       -       right rear side of fuse box
Notes: Warning! When doing door locks on these trucks make sure you DO NOT cycle the door locks rapidly. This may cause the ETACS module to fail and the door locks will no longer work. Also, you MUST add diodes to the lock and unlock output from our units to prevent damage to the ETACS. Make sure you insert the diodes with the cathode (stripe side) towards our unit.
Power Unlock      BLACK/ blue       -       right rear side of fuse box
Lock Motor
Unlock Motor
Parking Lights+      GREEN / WHITE             headlight switch
Parking Lights-
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light      red or RED / blue       +       driver kick, harness to rear
Door Trigger      GREEN/ red       -       top of fuse box
Notes: In a 2 pin plug. Also found in the drivers A pillar.
Dome Supervision
Hood Pin
Trunk/Hatch Release
Power Sliding Door
Factory Alarm Arm      blue / YELLOW       -       drivers kick panel
Factory Alarm Disarm      BLACK/ red       -       drivers kick panel
Disarm No Unlock
Tachometer      wht/blk or white             coil or ignition module
Notes: On the 2.4L, tach is wht/blk at the coil on the left front of the engine compartment. On the 3.0L and 3.5L it is white at the ignition module next to the coils on the right rear side of the engine compartment under the plastic motor cover.
Wait to start
Brake Wire      green       +       brake switch
Parking Brake
Horn Trigger      green       +       horn or relay underhood
Memory Seat 1
Memory Seat 2
Memory Seat 3
Yes      Type:
Transponder
Part #: 556UW
Notes:
warning
Saturday, April 25, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
