2000 Accord, factory alarm disarm
cpugh
Member - Posts: 17
Posted: December 13, 2006 at 2:20 PM / IP Logged
I need help finding hte wire that is the factory alarm disarm.  I have looked at the wire diagram that is listed on this site and all it says is w/locks.  Can someone tell me what this means?
cp
kaezoo
Copper - Posts: 125
Posted: December 13, 2006 at 2:39 PM / IP Logged
It means that that the factory alarm disarms when the key is turned in the door, and that this action also unlocks all the doors. The diagram simply uses the wires that monitor the door key switch to do all the locking and unlocking functions as well, so whenever the aftermarket system unlocks the doors it also disarms the alarm.
KarTuneMan
Platinum - Posts: 7,056
Posted: December 13, 2006 at 4:12 PM / IP Logged
FACTORY ARM Arms with lock wire    -
 Use these wires for vehicles with factory alarm only. They are found in the green connector at the top of the passenger side fusebox. Disarm without unlock is BLUE inside driver's door. For Accord LX with no factory alarm, use BLACK/ WHITE(lock) and GREEN/ RED(unlock) found on a two pin plug at the front of the driver's side fusepanel.
 FACTORY DISARM Disarms with unlock wire    -
chris354
Silver - Posts: 253
Posted: December 13, 2006 at 10:57 PM / IP Logged
If its a lx it will only arm and disarm with factory remotes. If its an ex it will arm and disarm with lock and unlock. If you are wanting to disarm without unlocking doors, on the ex its a blue wire in the drivers door at the power window switch, If its a lx the wire is at the factory keyless/alarm module attached to the drivers underside dash panel.
Thursday, September 4, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
