remote start problems, 96 Explorer
5kwatts
Member - Posts: 27
Posted: December 21, 2006 at 1:22 PM / IP Logged
hi i have a 96 Ford Explorer with a chapman CSM-2.5 remote controlled car starter and like a month ago the truck started makin a weird clicking sound and i took it to HORIZON AUDIO and they told me that a "relay was sticking"? its like the truck is trying to start when the keys are not in the ignition or when i dotn press the start button.  any ideas ?
customak47
Copper - Posts: 164
Posted: December 21, 2006 at 1:29 PM / IP Logged
It probably is a bad module. if it is causing problems, disconnect the module and install a new unit.
My rifle is my friend...
5kwatts
Member - Posts: 27
Posted: December 21, 2006 at 1:31 PM / IP Logged
maybe there is a way i can unhook the power wire so i can bypass it ?
5kwatts
Member - Posts: 27
Posted: December 21, 2006 at 1:33 PM / IP Logged
i have no idea how to unhook it. i got the owners manual for the remote starter.... so couldent i just unhook a power wire from the remote starter and go from there ?
thepencil
Gold - Posts: 1,526
Posted: December 21, 2006 at 1:37 PM / IP Logged
You know the saying if it ain't broken...
So, what exactly is broken in your post? I don't quite know and understand what it is.
Be careful whose advice you buy, but be patient with those who supply it.remote start problems, 96 Explorer -- posted image.
5kwatts
Member - Posts: 27
Posted: December 21, 2006 at 1:47 PM / IP Logged
ITS THE REMOTE STARTER I GUESS  IT IS TRYIN TO START THE TRUCK AND IM NOT PRESSING ANY BUTTONS AND THE KEYS ARNT EVEN IN THE IGNITION SO I JUST WANNA UNHOOK IT CUZ I DONT EVEN USE IT.... SO IS THERE A WAY TO DO THAT AND THE TRUCK WOULD STILL WORK OR NO?
splaudio
Copper - Posts: 237
Posted: December 21, 2006 at 3:17 PM / IP Logged
yes find the starter brain and unplug the power harness. power harness has 10-12gauge wire...
5kwatts
Member - Posts: 27
Posted: December 21, 2006 at 3:22 PM / IP Logged
i need the wire diagram of the ignition harness and where it is located please.
splaudio
Copper - Posts: 237
Posted: December 21, 2006 at 4:10 PM / IP Logged
the ignition harness us under the steering wheel. take off the plastic pannel below the wheel by ur shins.
12v+ PURPLE / red 15amp shold be ran to the battery
starter+  blue/white
ign+ WHITE/ orange
acc+ PURPLE / green
u dont need the keysence wire for remote start
u will also need a transponder bypass...
Hymer
Silver - Posts: 695
Posted: December 21, 2006 at 4:46 PM / IP Logged
just pull the fuses on the 12awg red wires, before ya go cutting wires.... that'll kill any power to the unit....
Tire Proz Stillwater Mn
High End Restyling and Comlete Repair
