DEI 1700G, 2005 Trailblazer
nojooms
Member - Posts: 6
Posted: December 24, 2006 at 5:06 PM / IP Logged
Could you help me,How to install the DEI 1700G on 2005 Trailblazer with Ultra start 1270TL remote starter.
which wire to use on DEI 1700 to which wire on the car, thanks
mikvot
Gold - Posts: 1,043
Posted: December 24, 2006 at 5:49 PM / IP Logged
you need a bypass module on that thing.
nojooms
Member - Posts: 6
Posted: December 24, 2006 at 7:10 PM / IP Logged
I have the DEI 1700G
mikvot
Gold - Posts: 1,043
Posted: December 24, 2006 at 8:36 PM / IP Logged
12volts
  red (40A), RED / white (40A)
  ignition harness
Starter  yellow   +   ignition harness
Second Starter  N/A
Ignition  pink   +   ignition harness
Second Ignition  white   +   ignition harness
Third Ignition  N/A
Accessory  orange   +   ignition harness
Second Accessory  brown   +   ignition harness
Keysense  lt. green   -   ign harn or BCM, tan plug, pin E3
Power Lock  use Directed module 1700G
Power Unlock  see power lock
Lock Motor  gray   5wi  driver door module in door
Unlock Motor  tan   5wi  driver door module in door
Parking Lights+  brown   +   fuse box under left rear seat
Parking Lights-  gray/black   -   switch or BCM, tan plug, pin E5
Hazards  white   -   hazard switch
Turn Signal(L)  dk. green   +   turn signal switch
Turn Signal(R)  lt. green   +   turn signal switch
Reverse Light  lt. green   +   fuse box under left rear seat
Door Trigger  use dome supervision wire   -   see notes
Dome Supervision  gray/black   +   fuse box under left rear seat
Trunk/Hatch Pin  use dome supervision wire
Hood Pin  pink/black (export only)   -   switch or BCM, tan plug, pin E6
Trunk/Hatch Release  N/A
Power Sliding Door  N/A
Factory Alarm Arm  arms with 1700G
Factory Alarm Disarm  disarms with 1700G
Disarm No Unlock  lt. green (if no 1700G)   -   driver door module in door
Tachometer  white   ac   cluster or PCM/ECM, blue plug
Wait to start  N/A
Brake Wire  white   +   brake pedal switch
Parking Brake  lt. blue   -   switch or fuse box under LR seat
Horn Trigger  BLACK / YELLOW to black   -   switch or BCM, tan plug, pin E12
Memory Seat 1  white   +   driver door module in door
Memory Seat 2  purple   +   driver door module in door
Memory Seat 3  N/A   +
nojooms
Member - Posts: 6
Posted: December 25, 2006 at 1:22 AM / IP Logged
thanks for info,But my question is,How to install the DEI 1700G unit to the car.
kgerry
Platinum - Posts: 3,455
Posted: December 26, 2006 at 10:34 AM / IP Logged
didnt it come with instructions?  it hooks up also identically to the 457G.....
on the bench you wire up power, ground, status, lock, unlock.... and take it to the vehicle and connect the violet data wire...... then you select vehicle platform and program it for that specific platform.....
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
chris354
Silver - Posts: 253
Posted: December 26, 2006 at 11:03 PM / IP Logged
The purple wire on the 1700 to the purple wire at the diagnostic plug under the dash.
