2005 montana remote start
gregkreuger
Member - Posts: 7
Posted: December 29, 2006 at 6:15 PM / IP Logged
hello, im currently installing a remote start on my montana and cant seem to find the location of the ignition harness wiring,  igniton control module,  i have the drawing and the igniton #1 is pink, and i see about 8 pink wires in the main bundle going across the engine,
thanks in advance for any advice,
greg
prdjr165
Copper - Posts: 293
Posted: December 29, 2006 at 6:34 PM / IP Logged
The ignition harness is the wires coming out of the ignition switch,usually behind the dash coming down the steering column.
gregkreuger
Member - Posts: 7
Posted: January 01, 2007 at 11:33 AM / IP Logged
good day,
i am installing a "radiostar generation" LCD remote and so far its been trouble, i cant get the starter to engage, all the door locks work, when i press for a remote start the accessory comes on but doesnt start, i tried the turbo short run and that worked,  i think my problem is with the (+) ignition input of the key cylinder to alarm, i connected this to same wire as  (+) ignition output of the heavy guage harness,?
not sure where to go from here,
thanks in advance, happy new year.
greg
chris354
Silver - Posts: 253
Posted: January 01, 2007 at 12:28 PM / IP Logged
On that  vehicle it has pass key 3 anti theft system that has to be bypassed. See if you can put the key in the ignition dont turn it then try to rs. If it starts thats the problem.
gregkreuger
Member - Posts: 7
Posted: January 01, 2007 at 12:37 PM / IP Logged
okay tried that but it still didnt start, my bypass when i start it the led goes off, my remote sends a (-) 200ma to the passkey, is this the same as ground when running?
chris354
Silver - Posts: 253
Posted: January 01, 2007 at 12:59 PM / IP Logged
What type of bypass are you using.
gregkreuger
Member - Posts: 7
Posted: January 01, 2007 at 1:02 PM / IP Logged
I am using Platform #06  Firmware:PKG5   Passkey 3
greg
maxcat
Copper - Posts: 211
Posted: January 01, 2007 at 1:24 PM / IP Logged
Hi there , On that remote start there is a wire labled neutral safety switch input. If the vehicle can not be started while in gear, then just connect this wire to a ground. This wire neend to see ground before the start proccess will start.
gregkreuger
Member - Posts: 7
Posted: January 01, 2007 at 1:39 PM / IP Logged
Can someone tell me what the Driver's Lock/Unlock motor's are???
gregkreuger
Member - Posts: 7
Posted: January 01, 2007 at 2:05 PM / IP Logged
feeling silly, i needed to have the park brake on for the unit to start,
and it starts, thanks for all your help, i love this website.
onto my next challenge.
greg
