2003 ford focus clutch bypass
oakley2000sel
Member - Posts: 33
Posted: December 31, 2006 at 2:30 PM / IP Logged
I installed the r/s everything is ready to go except for the clutch bypass. Does anybody know how and which wires I need on the clutch switch? Thanks in advance.
Ravendarat
Platinum - Posts: 2,806
Posted: December 31, 2006 at 2:46 PM / IP Logged
There is a black plug at the clutch with two BLACK/ red wires, the one you need is the top one. You need to send a negative pulse to that wire at the same time as you send the positive signal to the starter wire in the column. If your starter has a negative start output like a compustar then use that, if it does not you can use a relay and use the positive starter wire as your trigger.
oakley2000sel
Member - Posts: 33
Posted: December 31, 2006 at 4:52 PM / IP Logged
Thanks that worked great! Now running into another situation. I purchased the PKF2 Bypass Kit from 12 volt. Hooked it up but when attempting to r/s the vehicule just keeps cranking. I know it's the bypass because it will start using r/s with the key in the ignition. I pulled the connector off the PATS module and I assumed I had the TYPE B so that's how I hooked it up. Does anybody know what type the connector is? There is TYPE A, B, C, D. Thanks again!
