Alarm w/factory Keyless Entry?
01trublugt
Copper - Posts: 112
Posted: January 08, 2007 at 2:46 PM / IP Logged
Ok well I have been searching every vendor site, this board and every artical I could find on the net for this info.
Is there any stand alone car alarms that can be programed to use a factory keyless entry fob.
I know DEI makes an add on system but I am looking for something completely independant of the factory system. Normaly using an aftermarket FOB would not be an issue but the Keyless entry buttons ar on the key itself so it would seem stupid to have a key with buttons and a seperate fob for the alarm.\
Thanks.
Twelvoltz
Platinum - Posts: 2,384
Posted: January 08, 2007 at 3:15 PM / IP Logged
There is nothing I am aware of that would interpret the commands from your factory key fob to activate and deactivate an after market alarm.
All of the add on alarms I am aware of use the lock and unlock of the vehicle to arm and disarm.
01trublugt
Copper - Posts: 112
Posted: January 08, 2007 at 3:28 PM / IP Logged
OK Then on to the next question lol.
I am building a 67 Mustang and though it will be old I am still trying to add alot of modern features to it. I am using an ignition cyl off of an Acura which has a laser cut key...and the key that goes with it is a switchblade key with the keyless entry contols built into it.
Since this is a ground up build does anyone know where I can get the factory Acura keyless entry brain without going through a dealership???
Hymer
Silver - Posts: 695
Posted: January 08, 2007 at 4:05 PM / IP Logged
Go to some of the tuner / import car sites, those guys will strip things out and sell the origuinal parts... programing things may be a challenge
Tire Proz Stillwater Mn
High End Restyling and Comlete Repair
rudydapimp
Copper - Posts: 390
Posted: January 08, 2007 at 4:09 PM / IP Logged
there has to be something. heck, bulldog has remote starts that you can program onto your existing key fob. just did one on an alero.
Monday, February 2, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
