AstroStart’s manual interface module?
green6767
Copper - Posts: 209
Posted: January 13, 2007 at 10:17 AM / IP Logged
im installing an AstroStart 2101 on a 98 Jeep Wrangler manual transmission.  I normally dont do manual transmissions because of the pain with em.  The cluth bypass shouldn't be a problem, direct hookup from the starter wire from the astrostart.  I am using Astrostart's manual interface module and its throwing me for a loop here.  the diagram shows configurations for multiple kinds of setups....and i'm having a hard time figuring this one out.  The Jeep only has two doors, and I have found and tested the door pins.  Shows positive when door is shut,and negative when door is open.  Does anybody know how I would go about using the manual interface with the door pins?  The remote starter itself, clutch bypass, and e-brake monitoring shouldn't be an issue.  Just how to hook up the interface to the 2 door pins.  Thanks for any help guys!!!
Shaun, we are the same height, that is neat!
12V Installation Technician for Honda, Dodge, Chrysler, Toyota and Jeep.
KarTuneMan
Platinum - Posts: 7,056
Posted: January 13, 2007 at 11:08 PM / IP Logged
The white door pin wire NEG(-) goes to the door pin wire. The purple POS(+) door pin, goes to 12V. You need to "use" both.
If you had POS(+) door triggers, you would co0nnect the white door pin wire to ground.....you see, use both.
Yes, take the dark blue starter wire to the yellow/red @ the clutch switch.
The green from the Manual  modual, goes to the grey/black in the center console for the ebrake.
Let me know if you need ANY more help...I believe in this product.
green6767
Copper - Posts: 209
Posted: January 15, 2007 at 3:38 AM / IP Logged
i got it figured out before i read the response to my post. I did exactly as you posted! It was way too easy..i was just overthinking it. Its actually a great product and i would consider doing more manual transmissions with this thing. Thanks for the reply though!
Friday, February 6, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
