Immobilizer Bypass Relay
freebeer761
Posted: January 16, 2007 at 9:42 PM / IP Logged
Hi All.  I'm installing a Compustar remote starter on my 1998 S10 Blazer.  After getting most of my wires mapped out I remembered that this vehicle has a aftermarket Immobilizer installed.  The unit is a Autowatch 573PPI.  I know that a relay can be put in place that will bypass the Immobilizer while the remote starter is operating.  I could tear all the wiring apart to see where  everything connects, but I thought I would check to see if someone more experienced than I could share a diagram of what I should do.  Initial inspection shows connections to the ignition coil and the fuel pump.  A pdf of the installation manual would be helpful too.  Thanks in advance.
Platinum - Posts: 12,488
Posted: January 16, 2007 at 10:59 PM / IP Logged
Find where the installer cut the wires and wire in relays to temporarily reconnect the cut wires during remote start. I've done this before where a customer brought me a vehicle that had the immobilizer installed prior to the remote start being installed.
