Prestige APS997, 01 Hyundai Tiburon
paradice1130
Member - Posts: 29
Posted: January 25, 2007 at 9:57 PM / IP Logged
Hey guys. Im installing a Prestiege APS997 Alarm/Starter in my 2001 Hyundai Tiburon. I got a few questions, I never installed this advanced of an alarm before. I think I got the alarm part to work, but I cant get the remote start to work. Ive got all the starter wires hooked up properly, but when I try to start the vehicle, it says "inhibit" on the screen. What does that mean? Now I know it came with this inhibit relay, but I wasnt sure oif that was optional. Im trying to figure out how to get this alarm to start the vehicle properly. I installed a Pro Start in the vehicle last year, no problems, and used all the same wires I did on that setup, so I dont see why it wont start now. Anyone got any ideas. It be great. Dont know why, there isnt a trouble shooting in the 2 manuals that are over 25 pages.
Thanks.....
imseth85
Copper - Posts: 71
Posted: January 25, 2007 at 11:15 PM / IP Logged
check the position that the valet switch is in, and make sure the neutral safety wire is hooked up or grounded. That's your problem.
Seth Alvo     NY
Mobile Electronics Installer
Chris Luongo
Platinum - Posts: 3,746
Posted: January 26, 2007 at 6:44 AM / IP Logged
There is no neutral safety wire on the APS-997, and the valet switch is not related to the remote start.
--The control switch must be plugged in and in the on position.
--The brake wire must not see positive power.
--The hoodpin wire must not see ground.
--The tach rate must be programmed. If you prefer to use voltage sensing instead of tach, you must program the unit for voltage sense.
paradice1130
Member - Posts: 29
Posted: January 26, 2007 at 6:52 AM / IP Logged
What Neutral Safty wire? The alarm has one? Do I need to hook up the Alternate Ignition Harness & The Starter Inhibit Realy, or are they both optional? Like I figured alot of the extra harnesses were optional.
paradice1130
Member - Posts: 29
Posted: January 26, 2007 at 6:56 AM / IP Logged
What is the control Switch? I am unsure if the brake wire is + or -. I know the hoodpin is fine. And how do you program the tach or get it on Voltage Sense mode?
Thanks for the help.
paradice1130
Member - Posts: 29
Posted: January 26, 2007 at 6:57 AM / IP Logged
Sorry, the hoodpin. I only have the orange wire hooked up to it, i noticed in the diagram it shows 2 wires, one goes to the negative shut down? Where is the negative shutdown wire?
mdbetts
Member - Posts: 10
Posted: January 26, 2007 at 10:49 PM / IP Logged
The control switch is in a plastic bag with the pin switch and diode piece. Simply cut of the switch, butt connect the two wires together and plug it into the red two pin plug on the side.
cant hold me!
paradice1130
Member - Posts: 29
Posted: January 27, 2007 at 11:45 PM / IP Logged
I recently installed a Presteige Alarm in my girlfreinds tiburon. I was wondering if anyone has access to the wiring diagrams for a 2001 Hyundai Tiburon. I accessed the ones that are on this website, but dont have what Im looking for. I want to know what color wires & what plug there located on, for the lights on the dash, one is the door trigger wire which lights up the red sumbol on the dash, and the other is the wire for the rear hatch that lights up yellow. If anyone knows the color of these 2 wires that be great.
Thanks guys.
KarTuneMan
Platinum - Posts: 7,056
Posted: January 27, 2007 at 11:48 PM / IP Logged
What are you trying to do?
paradice1130
Member - Posts: 29
Posted: January 28, 2007 at 9:41 PM / IP Logged
Im want to use them for the trigger in puts. I had trouble locating the wire under the dash, so I found the wire running underneath the door sill and connected there. But its only the drivers side door. The listed wiring diagram for this car, has a couple incorrect descritions. Even the Parking light wire,  is listed as GREEN / WHITE on the gray harness, i tried it and its a dead lead, has nothing to even do with the parking lights. If anyone knows the correct location and color of the parkin light wire, that be great to.
I want to know, so I can have my trigger for the doors on that wire, and use the open rear hatch light as my rear trigger instead of installing an aftermarket trigger.
Page of 3
