door lock problems
audio Xclusive
Member - Posts: 30
Posted: May 22, 2002 at 11:44 PM / IP Logged
I installed a crime stopper cs 2006fm in a 91 chrysler labarron.  the according to the database the door locks are rev polarity and lock is orange and unlock is pink.  I could not find a solid orange wire behind the glove box and the only solid pink wire tested a continueous 12 volt positive.
I did find a ORANGE / black wire and lower in the passengers kick panel I found a pink/black wire.  Those wires test nother at rest and 12volts at lock for the ORANGE / black then 12volts at unlock for the pink/black.
those are the wires i used and they works okay for about two days  the drivers door operated much slower then the passenger door at first .  now the passenger side works great still but the drivers side only tries to work without unlocking the whole way.  I can hear it tring but it seams that it's not getting enough power to the drivers door.
i believe the relays are correct because if not i don't think it would of worked at all.  maybe I need to find the solid orange and the solid pink wire to tap.
another though at the relays I saw a diagram that came with the alarm for wireing rev polarity locks and it was different then the diagram i have from here.  it shows the lock and unlock wire going into the relays from the alarm and from the vehicle switch then out to the motor legs.  in other words it showed dissconnecting the factory wires going from the vehicles power door lock switch to the motor legs. then running the wires throught the relays.
switch------------------motor legs
switch-----------------relays------------------motor legs
needless to say i worked a long time on this car and any help would be greatly appreciated.
thanks
another Xclusive installation
Chris Luongo
Platinum - Posts: 3,746
Posted: May 23, 2002 at 5:43 AM / IP Logged
For a short time, my girlfriend had an '88 LeBaron, which I put alarm/keyless/trunk/remote start in.
The locks were a reversing polarity system, meaning you need your own relays...The correct wires were in the driver's kick panel, behind some thick insulation, coming in from the door boot.
If it's easy to pop out the switch on the door, do so, and test everything there.  If the wires are thin, you likely have onboard relays.  If they're very thick, you probably don't.  Anyway, once you get a good look at what the correct wires look like, it's easier to find them inside the car someplace.
the12volt
Administrator - Posts: 3,957
Posted: May 23, 2002 at 8:05 AM / IP Logged
Hi Xclusive, your vehicle has 5 wire alternating 12V+ door locks.
door lock problems -- posted image.
As far as the difference between diagrams, you were probably looking at the "Actuators / Reverse Polarity" diagram just beneath the one above shown here: https://www.the12volt.com/doorlocks/page3.asp#5w
Here's the rest of the information I have for your vehicle: https://www.the12volt.com/installbay/alarmdetail/634.html
the12volt
Moderator - Posts: 12,488
Posted: May 23, 2002 at 10:50 AM / IP Logged
This is what I have for wire colors for hte LeBaron ( Coupe ) : Hope it helps
Chrysler
Lebaron Coupe
1990-1994
Alarm and Keyless  Entry Wiring Colors and Notes
Function
Vehicle  Color
Location
Constant  +12 Volts:
RED AND PINK/BLACK
IGNITION SWITCH HARNESS
Starter  Kill:
YELLOW
Ignition  +12 Volts:
DARK BLUE
Dome  Lights/Superv:
YELLOW
(-) PIN SWITCH OR AT COURTESY LIGHT
OEM Horn:
BLACK/ RED (-)
STEERING COLUMN HARNESS OR AT RELAY
Power  Lock:
ORANGE / VIOLET
DRIVER'S KICK PANEL **
Power  Unlock:
PINK/VIOLET
Trunk  Release:
N/A
Alarm  Input Wire:
YELLOW
Notes:
** 1990 Door Locks Are Positive Pulse, 1991-92 Door Locks Are Reversal Rest At Ground, 1993-94 Door Locks Are A Split System Door Locks- Lock Is Positive Pulse System, Unlock Is Reverse Polarity Door Lock System, Lock is Positive Pulse Door Lock System
Sunday, December 21, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
