problems with 06 civic remote starter
newinstaller
Copper - Posts: 160
Posted: February 13, 2007 at 7:14 PM / IP Logged
Hi,
I am noticing that alot of the 06 civics that we do and some 07 RDX are having the same issue. In the mornings the car does not start during remote start. It tries 3 times than shuts off. But once the car has be driven it starts no prob
It is a bypass issue I believe
Anyone have any light on this.
We use the Honda SL3 & Honda SL2
cutter1122
Copper - Posts: 103
Posted: February 13, 2007 at 7:30 PM / IP Logged
use XK05 PKH4 www.bypasskit.com
JWorm
Platinum - Posts: 2,208
Posted: February 13, 2007 at 8:09 PM / IP Logged
You need to determine the problem before we can make a recommendation. My guess would be either tach, or transponder. You need to watch what the key symbol does in the instrument cluster when trying to remote start in the morning. It should behave the same way remote starting, as it does when starting by key. If a customer isn't willing to leave it overnight so you can see the problem, have them go out to the car in the morning and watch the key symbol. Also, have them describe what the car is doing. Cranks for a while...then stops, doesn't crank long enough, starts for a couple seconds...then shuts off?
Are you using tach, or voltage sensing?
What brand remote start are you using?
green6767
Copper - Posts: 209
Posted: February 14, 2007 at 12:08 AM / IP Logged
We've had quite a few brand new Hondas needing new batteries before the customer even gets their car. The past 6 months or so, the brand new lot Honda's have done this. They wont remote start, but soon as you put a jumper on the battery, fires right up. So when this happens, the Honda technicians load test the battery, and about 95% of the time, the battery is faulty from the factory. No idea why, bad batch maybe. But warranty from the service dept. always put a fresh new battery in and we never hear from the customer again. Problem solved. Hope this helps ya.
Shaun, we are the same height, that is neat!
12V Installation Technician for Honda, Dodge, Chrysler, Toyota and Jeep.
patmar
Copper - Posts: 69
Posted: February 14, 2007 at 9:24 AM / IP Logged
i have same problem with my 06 civic in last week. dealers replace my batterie and now start every cold morning.
newinstaller
Copper - Posts: 160
Posted: February 14, 2007 at 11:50 AM / IP Logged
We always use the injector for the tach. And I use the Compustar units
I am confused now.
thepencil
Gold - Posts: 1,526
Posted: February 14, 2007 at 12:45 PM / IP Logged
newinstaller wrote:
Hi,
COMPUSTART IS THE PROBLEM!!!!!!!!!!!!!!!!!!!
The problem is the Compustart unit not a bypass at all. I have been replacing Compustart unit on 06 Civic this entire three week with my other brand Autostat. No more calls about not starting in the morning. I think it has something to do with the tach signal at the injector when the temperature drops.
Be careful whose advice you buy, but be patient with those who supply it.problems with 06 civic remote starter -- posted image.
newinstaller
Copper - Posts: 160
Posted: February 14, 2007 at 1:10 PM / IP Logged
what if I go tachless
The V1 units do it
thepencil
Gold - Posts: 1,526
Posted: February 14, 2007 at 1:32 PM / IP Logged
Only one way to find things out.
I aways use tach, so you will have to post your finding.
