1997 ford contour power lock issue's
lex305
Member - Posts: 8
Posted: February 27, 2007 at 3:17 PM / IP Logged
How do i add power locks with this alarm? the alarm is a autopage RF-420LCD...... also the door trigger,the car's dome light don't work how can i get the alarm to sound when this happens? Thanks in advance.......
lex
Hymer
Silver - Posts: 695
Posted: February 27, 2007 at 3:37 PM / IP Logged
You WILL need o add [2] relays, unless the alarm has them built in.
Lock WHITE/ green (+) Unlock YELLOW /GREEN (+).. Sorry I don't have he door pin wires listed.. Trunk pin BLACK/ orange in the trunk (-).. Check the fuse and the bulbs at the dome ligh ckt in both the car and the alarm...
Tire Proz Stillwater Mn
High End Restyling and Comlete Repair
lex305
Member - Posts: 8
Posted: February 27, 2007 at 3:50 PM / IP Logged
I'll try that thank you.
lex
Monday, December 15, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
