designing a 12v interceptor circuit/relay
m_pugliese
Member - Posts: 15
Posted: March 07, 2007 at 3:01 PM / IP Logged
OK, I'm trying to figure out a way to Open a normally Closed circuit using a 12V source to open the light circuit. The light has to work except for when I do not  want it to (the momentary switch). The way I have to set this up is for me to supply 12V to either a set of relays (which I have little experience with) or a circuit. Basically, here's a vague run down of what I'm trying to do. Someone who knows relays may be able to help me on this. This design would have some great uses for people working on their cars.
Here's a vague work scratch for what I'm trying to do. Any help would be greatly appreciated.
designing a 12v interceptor circuit/relay -- posted image.
Hymer
Silver - Posts: 695
Posted: March 07, 2007 at 4:11 PM / IP Logged
a standard 5 pin bosch relay will do what ya want
pin 85 to momentary (12v whn switch closes)
pin 86 to ground
pin 30 to 12v
pin 87a to the input of the lite
pin 87 to???
when the relay gets 12v from your switch it will flip the 87a contact to 87 [turning off the lite] and supplying 12v to pin 87 of the relay [for whatever purose you want...
Tire Proz Stillwater Mn
High End Restyling and Comlete Repair
m_pugliese
Member - Posts: 15
Posted: March 07, 2007 at 7:16 PM / IP Logged
Thanks. I figured a relay would work, but like I said...I Don't Know Jack About Relays!
Thanks a ton!  designing a 12v interceptor circuit/relay -- posted image.
m_pugliese
Member - Posts: 15
Posted: March 31, 2007 at 9:39 PM / IP Logged
well...
m_pugliese
Member - Posts: 15
Posted: March 31, 2007 at 9:40 PM / IP Logged
I think...
m_pugliese
Member - Posts: 15
Posted: March 31, 2007 at 9:41 PM / IP Logged
this could be used...
m_pugliese
Member - Posts: 15
as an interceptor...
m_pugliese
Member - Posts: 15
Posted: March 31, 2007 at 9:42 PM / IP Logged
for lights...
m_pugliese
Member - Posts: 15
Posted: March 31, 2007 at 9:43 PM / IP Logged
you don't want to light up...
m_pugliese
Member - Posts: 15
when "someone" gets behind you.
