07 ram 3500 can sl2 i
mustang347
Member - Posts: 7
Posted: March 22, 2007 at 4:52 PM / IP Logged
Installed a Autopage 860 remote start alarm in a 97 Ram 3500 along witha  CAN-SL2-i and an ignition bypass and now when you turn the ignition off, the flashers flash 4 times. Everything works properly and if I unplug the CAN module the flashers do not flash. Any idea what could be causing this?
Platinum - Posts: 12,488
Posted: March 22, 2007 at 9:34 PM / IP Logged
Have you tried removing the fuse on the Autopage and trying the same thing ? The CANSL2 doesn't control the parking lights where as the Autopage does. Chances are it's your Autopage unit is doing it, but post your results.
mustang347
Member - Posts: 7
Posted: March 23, 2007 at 8:37 AM / IP Logged
If I unplug the parking light output from the alarm itself the flashers still flash when you turn off the ignition. If I take the Can module out of play, the flashers do not flash with you remove the key.
Thursday, February 5, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
