1993 mitsubishi colt, keyless entry
andrekr
Posted: March 27, 2007 at 6:14 PM / IP Logged
Hi
Just bought a keyless entry kit from eBay to install in my Mitsubishi Colt/Mirage 1993.
Discription:
BW-852- a full featured keyless entry with 4 button remotes, built-in relays, and a universal 2 door lock kit.
2 - four (4) button,  icon style remote transmitters
Plug in LED - Make thieves think you have an alarm!
Plug-in  multi-function, valet / override switch
Remote Panic mode
Horn / siren output
Ignition controlled door lock option - programmable
Programmable door lock pulse time
On-board relay for + park light flash
Output for domelight supervision / illuminated entry
Remote door locking / unlocking with on-board relays
Passenger unlock output
< color=#0000ff >Keyless entry - even in valet mode
< color=blue >Starter disable output
< color=blue >Auxillary output < color=blue > for trunk / hatch release, windows or ??
< color=#0000ff >Code learning receiver
< color=blue >Owners manual & Installation manual
Don't have so mch experience in this field, just some small car stero installations.
I got instructions to mount the lock motors, so I don't think that will be a problem. But I need help to do the wireing.
1. Where should I place the black box (relay?) and where do I plug in all the wires coming from this?
2. There are 2 wires (short ones) from the door motor, where does theese go?
3. How do I program the diffrent functions?
4. There is a small black wire coming from the black box (away from the others), what is this for?
I managed to get a wirering diagram  but I need some help to use this and locate the place where the wires go (and which).
Hope you understood some of my questions, at least. 1993 mitsubishi colt, keyless entry -- posted image.
I will be extremly happy for any help
Andre
Norway
alex79
Member - Posts: 16
Posted: March 27, 2007 at 7:29 PM / IP Logged
hey whats up...   chavo!!!
this information is for u ese!! check this..
WIRING INFORMATION: 1993 Mitsubishi Mirage
WIRE WIRE COLOR WIRE LOCATION
12V CONSTANT WIRE WHITE Ignition Harness
STARTER WIRE BLACK / YELLOW Ignition Harness
IGNITION WIRE BLACK/ WHITE Ignition Harness
ACCESSORY WIRE BLUE/BLACK Ignition Harness
POWER DOOR LOCK (-) BROWN / WHITE Harness Left Of The Steering Column
POWER DOOR UNLOCK (-) BROWN / BLUE Harness Left Of The Steering Column
PARKING LIGHTS (+) GREEN / WHITE Headlight Dimmer Switch
PARKING LIGHTS (-) GREEN/ YELLOW Harness At Steering Column
HEADLIGHTS (-) RED / YELLOW Harness At Steering Column
DOOR TRIGGER (-) BLACK Driver’s “A” Pillar
TRUNK TRIGGER (-) RED / GREEN At Light In Trunk
TACHOMETER WIRE WHITE Ignition Coil
BRAKE WIRE (+) GREEN At Brake Pedal Switch
HORN TRIGGER (-) GREEN/ RED Harness At Steering Column
LEFT FRONT WINDOW UP GREEN/ RED At Driver Window Motor Inside Door
LEFT FRONT WINDOW DOWN GREEN/ BLACK At Driver Window Motor Inside Door
RIGHT FRONT WINDOW UP RED / YELLOW Harness In Driver’s Kick From Driver Door
RIGHT FRONT WINDOW DOWN GREEN/ YELLOW Harness In Driver’s Kick From Driver Door
LEFT REAR WINDOW UP RED / GREEN Harness In Driver’s Kick From Driver Door
LEFT REAR WINDOW DOWN GREEN Harness In Driver’s Kick From Driver Door
RIGHT REAR WINDOW UP RED / BLUE Harness In Driver’s Kick From Driver Door
RIGHT REAR WINDOW DOWN GREEN/ BLUE Harness In Driver’s Kick From Driver Door
             just do it    !!
Sunday, February 15, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
