viper 300esp, 01 monte carlo
snakeiz2
Member - Posts: 7
Posted: April 04, 2007 at 8:36 PM / IP Logged
i have a viper 300esp with remote start on a 01 monte carlo  is it possible to just replace the brain for an updated dei alarm? wich model could i upgrade to? thanks
snakeiz2
Member - Posts: 7
Posted: April 11, 2007 at 9:28 AM / IP Logged
I have this alarm with remote start when i hade the remote start put in they said i would lose the opening the trunk option But i read that  this alarm i has an expandable option and could use a 4button remote as well so how is it that i would lose trunk option? Alarm is in a 01 monte carlo thanks.
mobilecustoms
Silver - Posts: 397
Posted: April 11, 2007 at 10:19 AM / IP Logged
TRUNK RELEASE BLACK (-), Requires #775 Relay   @ TRUNK RELEASE SWITCH
look at the 12 pin harness at the module there will be a RED / white wire in pin 12 and hook it to the black wire at the trunk release switch.
snakeiz2
Member - Posts: 7
Posted: April 11, 2007 at 12:28 PM / IP Logged
I read that on tha viper book but  then what would be the function on the remote to open it? i have the 2 button remote i press 1 for arm and un-arm and hold the secound one for 3sec. for starting. If i wire the alarm at the 12 pin for the trunk will it automaticly set for a remote 1and 2 at the same time for trunk? or do i have to take to be done with the bitwriter? thanks
mobilecustoms
Silver - Posts: 397
Posted: April 11, 2007 at 12:52 PM / IP Logged
it will be either button 2 held for 2 sec or 1 and 2 together
yiou can check this put with your multimeter if you have one. Test the wire and see what button(s) operate it. it should be button 2 held for 2 sec.
Twelvoltz
Platinum - Posts: 2,384
Posted: April 11, 2007 at 1:11 PM / IP Logged
Here is your install manual. Yes your system offers 2 aux outputs and as already stated holding button II activates channel 2 and pressing I and II activates channel 3.
snakeiz2
Member - Posts: 7
Posted: April 11, 2007 at 2:43 PM / IP Logged
Im just woundering why my viper installer said i cant is not because of a the key fob of the car is it? I asume since my starter is on the secound button for 2sec. it must be channel 3? so al i need is a relay for the trunk and wirer it up to the trunk release. thanks
mobilecustoms
Silver - Posts: 397
Posted: April 11, 2007 at 5:07 PM / IP Logged
yup
snakeiz2
Member - Posts: 7
Posted: April 11, 2007 at 7:32 PM / IP Logged
The viper hand book says i could upgrade to a 4 button remote, is it possible and if so what would be the the model number for it ? the two button is 471T or is there any other remote i could upgrade to thats compatiable? I searched for the 4 button but cant come up with the right model. Thanks
mobilecustoms
Silver - Posts: 397
Posted: April 11, 2007 at 7:54 PM / IP Logged
474t, 474v, 474p
eash one is eiother valet, viper, python- doesnt matter which one. they should program.
