powerstroke diesel, crimestopper?
greendually
Member - Posts: 11
Posted: April 16, 2007 at 5:16 AM / IP Logged
I installed a crimestopper alarm/starter in my truck.When i start the truck with the remote sometimes the truck will not start and the alarm will sound.But if i turn off the alarm the truck will start.It almost seems like the shock sensor is turning back on and stopping the starting process after it has started turning the starter over.
Hymer
Silver - Posts: 695
Posted: April 16, 2007 at 8:21 AM / IP Logged
disable the shock sensor, and arm it then start it for a few days, that should tell ya if its the shock sensor. If it is, then set the sensitivity down, and or remount it somewhere else..
Tire Proz Stillwater Mn
High End Restyling and Comlete Repair
greendually
Member - Posts: 11
Posted: April 17, 2007 at 3:00 PM / IP Logged
Well i turned the shock sensor all the way down,still did the same thing.Anyone have any ideas that i could check.
KarTuneMan
Platinum - Posts: 7,056
Posted: April 17, 2007 at 3:21 PM / IP Logged
How did you wire the "wait to start"
Where did you connect at?
What year is your truck?
greendually
Member - Posts: 11
Posted: April 17, 2007 at 4:23 PM / IP Logged
I didnt wire in the wait to start,i used a 20 sec delay.
All the connections are under the steering colum,what colors,i dont remember off hand.
My truck is a 2003 f350 7.3 diesel.
Thanks for your help.
KarTuneMan
Posted: April 17, 2007 at 5:51 PM / IP Logged
When the alarm is triggered....what zone does the LED tell you was set off? Does it say "shock sensor" (the # of flashes)
greendually
Member - Posts: 11
Posted: May 08, 2007 at 5:27 PM / IP Logged
when the alarm goes off,it says the doors got opened.Could it be the door trigger?
KarTuneMan
Posted: May 08, 2007 at 6:55 PM / IP Logged
Could be the bcm wake up, or yes, the door pin! How did you catch the door pins? where? Did you isolate the pins?
greendually
Member - Posts: 11
Posted: May 09, 2007 at 3:51 AM / IP Logged
I used the door dome light trigger.
greendually
Member - Posts: 11
Posted: May 10, 2007 at 3:17 PM / IP Logged
I did install diodes (i think thats what there called) to the trigger wire from the dome light wire.
