Autopage RS-750LCD Problem on 97 yukon
gunner_for_hire
Member - Posts: 37
Posted: February 09, 2003 at 8:08 PM / IP Logged
First off... Thanks for all the advice prior to my install!  I thought everything was going great, until I tested the door locks...
I initially had the unit hooked up for driver's priority function - it worked! But it was a pain to push and hold the button a second time to get the passenger's door unlocked. So I unhooked the positive lead from the battery and removed the relay for the driver's priority, then rearranged the blue and green (lock/unlock) wires on the other two relays.  I did a couple of other things, i.e. rerouted an aux. 12V wire.  Then I hooked the battery back up...  Problem.
When I push unlock on the autopage remote, the passenger's door unlocks perfectly, but the driver's door unlocks about 7 times (i.e. a series of 7 triggers to the unlock mechanism).  The driver's door will not lock (except manually), but the passenger's door will.  The original remotes (the ones from the factory) don't work now.  When you press lock or unlock on them, you hear some relay click, but nothing happens.  The rear hatch release on the original remote doesn't work either.
The switches for the door locks on the doors do about the same thing.  Pressing lock will lock the passengers door, but will cause a series of clicks at the driver's door.  Pressing unlock will unlock the passengers door but will cause a series of clicks at the driver's door.  But check this out.
I had the truck on "dome light override" ( a small button next to the headlight switch) that disables all the interior lights when the doors are open.  So I took it off this function to test the "domelight supervision" function.  When I take the truck off of "domelight override" the driver's door begins clicking just like when I push and hold the unlock switch.  The domelights don't come on immediately, but will begin to "flicker" in time with the "clicks", starting very dim and gradually increasing in intensity...
I must have fried something... But I don't really know for sure.  Any thoughts?
Thanks,
--Jeff
PS.. My remote start doesn't work either, but I will tackle one problem at a time...
gunner_for_hire
Member - Posts: 37
Posted: February 09, 2003 at 9:19 PM / IP Logged
Small update...
The driver's door clicks only 5 times when the "unlock" signal is received from the Autopage remote.
And my Remote Start DOES work, I just forgot to program it to "Voltage Sensing" mode as I'm not using a Tach. wire.
--JJ
securinu
Silver - Posts: 772
Posted: February 09, 2003 at 9:51 PM / IP Logged
what wires do you have for lock and unlock and how do you have it hooked up???
gunner_for_hire
Member - Posts: 37
Posted: February 10, 2003 at 5:30 PM / IP Logged
Ok,  here is my  install scheme for the doors and lights....
I tapped the Brown wire at the headlight switch with the White wire from Harness H2.
I used the Gray wire on H9 to activate the back hatch by cutting the black wire at the driver's kick panel.  This works fine.
The domelight relay is triggered by the white wire from H9.  I cut the white wire at the headlight switch and used it in the relay.  My relay is as follows...
30 - Truck side of white wire at headlight switch
85 - 12V constant
86 - White wire from H9
87 - 12V Constant
87a - Switch side of white wire at headlight switch.
As an aside, the "clicking" begins when I turn the domelight override switch to off (i.e. the domelights would normally come on when a door is opened).  So, I have this override feature turned on.  With the overide on and my relay (as above) in place, I can still turn on the domelights by rotating the dimmer wheel to the "on" positon.  The lights work fine.  I can also hear the relay click off after 15-30 secs after arming the alarm.  The domelights don't do anything... I assume that this is related to the domelight override switch being activated.  Consequently, the alarm will not trigger when the doors are opened....
The green wire from H6 is tapped into the Purple wire at the headlight switch.  This should receive a door trigger when a door is opened, but the purple wire does not change with the domelight override switch on.
Now the door lock relay...
I cut the lt. blue and white wires at a harness in the driver's kick panel.  Touching one side  of the light blue wire with 12V would lock all the doors.  Touching the other side did nothing. The same was true for the white wire.
So my lock relay looks like this...
30- Lt. blue wire that locks when pulsed
85-12V
86-Green wire from H7
87-12V
87a-Lt. blue wire that does not lock when pulsed
And my unlock is this...
30-White wire that unlocks when pulsed.
85-12V
86-Blue Wire From H7
87-12V
87a-White wire that does not unlock when probed
As I stated earlier, everything was working when I had it hooked up for the driver's priority unlock.  Then I decided it was too much hassle to unlock the passenger's door.  So I unhooked the battery and set my relays up as above (basically removed one relay, and moved the blue to the "driver's priority" relay).  Hooked the battery back up and this is what I have.  My original factory remotes don't work now (they did with the priority unlock), the driver's door will unlock with disarm, but clicks 5 times (I think this has to do with the length of the pulse from the Autopage unit).  No sound is heard in the driver's door with the arm command.  However, the passenger's door functions perfectly!  Locks and unlocks like a charm...  Also the driver's door will unlock using the switches on the any door, but will "Click" as long as you hold the unlock button down.  No sound is heard from the driver's door with an unlock command.
Also when you take the domelights off of override, the driver's door begins to unlock repeatedly (a series of clicks until you place the domelights back on override).  If you let this go for a few seconds, the domelights actually begin to light, but very dimly (i.e. the filaments turn orange) and gradually increase in intensity with each click, going off between clicks , all the while the driver's door is unlocking.  The passenger's door is normal!
That's about it.  If anyone needs any more info, please let me know!
--JJ
jrilla
Gold - Posts: 1,498
Posted: February 10, 2003 at 6:34 PM / IP Logged
Iust an obvious question:  did you hook back up the pink drivers priority unlock wire that you cut to install the relay?
You shouldn't have to do this: but it should work: If you use the blue unlock wire to trigger two relays: the relay you have it triggering now, as well as the relay you had installed between the pink drivers priority wire.  Like I said you shouldn't have to do this to get it to work, but I would give it a shot if you can't figure it out.
And I may be missing something, but why did you cut the domelight wire?  My info shows that the polarity is negative and would only need to be grounded for the lights to come on (still using a relay though). I thought I read in another post why you set it up like that but I may be wrong.
J Rilla
Owner/Installer
gunner_for_hire
Member - Posts: 37
Posted: February 10, 2003 at 9:01 PM / IP Logged
Ok, now if I was sending 12V through the parking light wire... The white wire at the headlight switch... Could that reak havoc on my system??????  That really could be it, if the polarity is negative, and I send 12V down the line, anyway it seems like it could cause problems in my limited knowledge.
Could you provide me with a relay setup for ground?  I assume that I would reconnect the white wire, make 30 a tap to the white wire, make 87 a ground, and keep 85 12V???
As for the other relay, I guess I could put it back in, but when I try to probe the tan wire to the driver's door, nothing happens.  So I don't understand that at all.
If you don't mind, give me a hint on how to hook up the domelight supervision, and I'll give that a shot before I spend $117 on a new keyless entry control module with relays.
Thanks for the lead!
--JJ
gunner_for_hire
Member - Posts: 37
Posted: February 10, 2003 at 9:02 PM / IP Logged
And no I didn't hook the pink wire back up, I just cut it.  Half in frustration I think.Autopage RS-750LCD Problem on 97 yukon -- posted image.
securinu
Silver - Posts: 772
Posted: February 10, 2003 at 9:28 PM / IP Logged
the park light wire is brown not white.
gunner_for_hire
Member - Posts: 37
Posted: February 10, 2003 at 9:34 PM / IP Logged
Sorry domelight wire... That is the one that I have relayed... I have the parking light wired tapped with the 12V 10A output from the alarm... It works fine.
I just took the relay out of the loop on the domelights... Reconnected the white wire at the headlight switch and no dice.  It still clicks.  Thanks for heads up though.
--JJ
jrilla
Gold - Posts: 1,498
Posted: February 10, 2003 at 10:02 PM / IP Logged
Make sure the pink wire is connected, you should be able to just plug the relay back in if you just pulled it from the harness, or if you cut the lreay harness out then just connect the two ends of the pink with a piece of wire since they may be too short now.  See if this improves anything and get back to me.
Leave the domelight wire alone until you figure out the problem.  The way you mentioned above should do just fine for a relay setup though.
Did you do anything with the door trigger yet?
If all of this does not work ,try pulling the three fuses on the Red power wires from the autopage and see if this improves things.  We need to narrow down the problem.  We can take it from there.
J Rilla
Owner/Installer
Sunday, September 14, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
