marcus vehicle tracking gps
prdjr165
Copper - Posts: 293
Posted: June 23, 2007 at 3:22 PM / IP Logged
Does anyone have a manual for any Marcus gps unit's or do you know if it will still work properly if the ignition(trigger)wire isn't hooked up? These units have a 3 wire conector:
red-power
blk-ground
white-power with ignition on
peterubers
Silver - Posts: 706
Posted: June 23, 2007 at 5:22 PM / IP Logged
The unit will never auto power on without the ignition sense wire hooked up.  So if your car was hijacked, the unit would never power on b/c it wouldn't know that the ignition was activated.
so, no, it would not work as intended.
The search function is your friend.
prdjr165
Copper - Posts: 293
Posted: June 23, 2007 at 6:32 PM / IP Logged
Thanks for the info!
