viper5900 sensor 1, 2 icon explain?
sufferrar
Copper - Posts: 190
Posted: July 09, 2007 at 9:46 AM / IP Logged
I have 2004 nissan wingroad with a viper 5900. I have installed the shock sensor and a 508d sensor. I have connected the 508 green wire to a relay and the relay output to the siren. So it is basically a chirping relay. The blue wire was just tied in to the blue of the shock sensor.
Here is what i want:
1 When the warn away from the shock sensor goes off i want icon 1 to be displayed.
2 When the warn away from the 508d sensor goes off i want icon 2 to be displayed.
3 If the full trigger of the shock sensor goes off i want icon 1 and the hammer to be displayed.
4 If the full trigger of the 508d sensor goes off i want icon 2 and the hammer to be displayed.
Given the way i have the 2 sensors connected can i get what i ask for ? or even pieces of it
"I'm So Loud It Hertz"
JWorm
Platinum - Posts: 2,208
Posted: July 09, 2007 at 9:54 AM / IP Logged
Blue and green of shock sensor to blue of shock sensor harness (just as it is from the factory)
Blue and green of 508D to green of shock sensor harness.
You don't need to have the 508d trigger a relay to trigger the siren. When the alarm sees those sensors triggered, it will chirp the siren.
deathshadow
Posted: August 08, 2007 at 6:30 PM / IP Logged
So wait... You are splicing in the Blue & Green wire from the shock sensor harness (first and second stage trigger wires) into the DoubleGuard Shock Sensor harness (which plugs into the brain). In which case it will chirp if 508D outer zone is violated and it will set off the full siren if the second stage is tripped?
Wiring it this way will also display icon 2 and the hammer for the 508D?
Sunday, April 5, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
