compustar in '90 celica
Bakedgoat
Member - Posts: 6
Posted: August 26, 2007 at 12:21 AM / IP Logged
I installed a compustar in my 90' Toyota Celica, and it doesnt seem to respond to anything. I've installed 3 in my lifetime, and they've all been successful installs. But now I'm trying to program a remote to the brain by turning the ignition fro ACC to On 5 consecutive times within 7 seconds, but the relay in the brain doesnt make any clicking noises, and my parking lights dont blink. I can confirm that the ground is good, and the 12V constant is good. Any help is appreciated.
Platinum - Posts: 13,726
Posted: August 26, 2007 at 9:06 AM / IP Logged
You need to verify the ACC connection.
KarTuneMan
Platinum - Posts: 7,056
Posted: August 26, 2007 at 9:45 AM / IP Logged
Cut the ign wire free, strip yourself a chunk of constant 12 volts (expose the wire) take your bare ign. wire from the brain and touch it to the bare 12volt wire 5 times in a row. You should then be able to program your transmitters. After you program, reconect the little green ign. to your harness.
Some key cylinders you just can't turn fast enough!   Try it, you'll see.
Bakedgoat
Member - Posts: 6
Posted: August 29, 2007 at 5:16 PM / IP Logged
Awesome, thanks for the suggestion guys. I'll post back after I've tried this. Also should the LED blink or the siren make any noise when I put the battery lead back on?
flashmcclain
Member - Posts: 24
Posted: September 01, 2007 at 12:44 PM / IP Logged
What were the results?
Educate.Educate.Educate!
