idatalink
eric-tech
Member - Posts: 20
Posted: September 18, 2007 at 12:40 PM / IP Logged
Just wanted to know if lots of installer were using Idatalink bypasses at this time.  They are great and reliable.
Comments...
Take your time, a solution is just around the corner :-)
extreme1
Silver - Posts: 1,070
Posted: September 18, 2007 at 2:35 PM / IP Logged
Comments...
So far my only complaint is I did a 2003 Infinity FX35 the other day with an ADS-AL-CA and the hood/door/trunk/tach outputs didn't work.
locks/bypass and security worked great. Every other vehicle worked exactly as they should have.
Shaughn Murley
Visions Electronics
Red Deer, Alberta
chadwa2003
Copper - Posts: 353
Posted: September 18, 2007 at 4:11 PM / IP Logged
They have pros and cons for gms they are great no problems I will never use one again on a for as the board on two of them shorted and caused the cars to get towed to mechanics. But other then that no complaints
extreme1
Posted: September 18, 2007 at 7:27 PM / IP Logged
I've seen the same problem with xpresskit stuff to, especially xk06 programmed to pkg9, vehicle sits and the battery goes dead, customer attemps to jumpstart and the unit locks up.
Shaughn Murley
Visions Electronics
Red Deer, Alberta
dre187
Copper - Posts: 129
Posted: September 18, 2007 at 10:00 PM / IP Logged
yep had the problem too, xk06 on a 2004 hummer h2. battery would die. took a while to narrow it down since it would take like a day for the battery to drain. i like the product. i find the chrysler modules don't work sometimes though
Tuesday, April 28, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
