pro start 2300 trigger wire
flashbang
Member - Posts: 29
Posted: September 26, 2007 at 8:16 PM / IP Logged
When I ground the pro-start 2300 trigger wire it starts fine. Now how do I get a negitive pluse from my OEM 2002 Jeep Grand Cherokee key fob Panic button to operate this remote starter?
I tested the wires comming form the remote key module in the passenger door panel with no luck?
Platinum - Posts: 13,726
Posted: October 01, 2007 at 7:00 PM / IP Logged
I am not at all familiar with your start module. Or your vehicle for that matter.   Can you select 1   2   or  3 pulses to activate it.  If so we set them to 3 pulse and press lock 3 times on the keyfob.  You may need to use a relay at the actuator motor to get you the ground pulse you need.
