2008 toyota sienna, keyless/remote start
lsondubz
Copper - Posts: 193
Posted: October 25, 2007 at 8:50 AM / IP Logged
Have a customer looking to get a Remote Start/Keyless for a 2008 Sienna, cant find wiring info...
Twelvoltz
Platinum - Posts: 2,384
Posted: October 25, 2007 at 9:03 AM / IP Logged
Here is what Audiovox lists:
          #513616: 2008 TOYOTA SIENNA MINIVAN WITH 3.5L ENGINE AND 6-SPEAKER AUDIO SYSTEM
     Audio/Mobile Video
     WIRE          COLOR          POLARITY          LOCATION
     Battery          BLUE / YELLOW          (+)          RADIO HARNESS
     Accesory          GRAY          (+)          RADIO HARNESS
     Ground          WHITE/ BLACK          (-)          RADIO HARNESS
     Illumination          GREEN          (+)          RADIO HARNESS
     Power Antenna          PINK/BLUE          (+)          RADIO HARNESS
     LF Speaker (+)          PINK
     LF Speaker (-)          VIOLET
     RF Speaker (+)          GREEN
     RF Speaker (-)          BLUE
     LR Speaker (+)          BLACK
     LR Speaker (-)          YELLOW
     RR Speaker (+)          RED
     RR Speaker (-)          WHITE
     Radio Security          YES
     Security
     Battery          WHITE/ RED          (+)          IGNITION SWITCH HARNESS
     Ignition 1          BLACK          (+)          IGNITION SWITCH HARNESS
     Starter 1          BLACK / YELLOW          (+)          IGNITION SWITCH HARNESS
     All Door Trigger          BLUE          (-)          IGNITION SWITCH HARNESS
     Domelight Super          BLUE          (-)          IGNITION SWITCH HARNESS
     LF Latch          RED / YELLOW          (-)          AT BCM MODULE BEHIND DRIVERS SIDE OF DASH NEAR STEERING COLUMN
               PIN #14
     RF Latch          RED / YELLOW          (-)          AT BCM MODULE BEHIND DRIVERS SIDE OF DASH NEAR STEERING COLUMN
               PIN #23
     LR Latch          GRAY          (-)          AT BCM MODULE BEHIND DRIVERS SIDE OF DASH NEAR STEERING COLUMN
               PIN #15
     RR Latch          RED / WHITE          (-)          AT BCM MODULE BEHIND DRIVERS SIDE OF DASH NEAR STEERING COLUMN
               PIN #16
     Trunk Trigger          GREEN / WHITE          (-)          AT BCM MODULE BEHIND DRIVERS SIDE OF DASH NEAR STEERING COLUMN
               PIN #25
     Hood Trigger          RED / WHITE          (-)          AT BCM MODULE BEHIND DRIVERS SIDE OF DASH NEAR STEERING COLUMN
               PIN #10
     Alarm Disarm          BLUE/BLACK          (-)          AT BCM MODULE BEHIND DRIVERS SIDE OF DASH NEAR STEERING COLUMN
               PIN #21
     Parking Lights          GREEN/ BLACK          (-)          IGNITION SWITCH HARNESS
     Convenience
     Headlights-Lo          RED / GREEN          (-)          AT VEHICLE LIGHT SWITCH HARNESS
     LF Pk Lt Bulb          GREEN          (+)          AT FRONT LEFT PARKING LIGHT
     RF Pk Lt Bulb          GREEN          (+)          AT FRONT RIGHT PARKING LIGHT
     LR Pk Lt Bulb          GREEN          (+)          AT REAR LEFT PARKING LIGHT
     RR Pk Lt Bulb          GREEN          (+)          AT REAR RIGHT PARKING LIGHT
     All Hazrd Lights          BLACK/ ORANGE          (-)          AT VEHICLE HAZARD SWITCH HARNESS
     Wipers-Lo          BLUE/BLACK          (+)          AT VEHICLE WIPER SWITCH HARNESS
     Wipers-Hi          BLUE/ORANGE          (+)          AT VEHICLE WIPER SWITCH HARNESS
     Remote Start
     Ignition 2          BLACK / YELLOW          (+)          IGNITION SWITCH HARNESS
     Accessory 1          PINK          (+)          IGNITION SWITCH HARNESS
     Anti-Theft Type          UNIVERSAL IMMOBILIZER
     Anti-Theft Descript          THE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER
     Key Sense          BLUE/BLACK          (-)          IGNITION SWITCH HARNESS
     Tachometer          GREEN/ RED          (AC)          AT ECM MODULE TO RIGHT OF GLOVEBOX
               PIN #5
     Speed Sense          VIOLET/WHITE          (AC)          AT ECM MODULE TO RIGHT OF GLOVEBOX
               PIN #17
     Brake Lights          GREEN / WHITE          (+)          AT SWITCH ABOVE BRAKE PEDAL
     Reverse Lights          RED / BLACK          (+)          IN HARNESS AT LIGHT
     Horn          GREEN/ BLACK          (+)          IGNITION SWITCH HARNESS
     Modules
     WIRE          LOCATION
     Module 1          ECM - BEHIND RIGHT SIDE OF DASH TO RIGHT OF GLOVEBOX
     Doorlocks/Windows
     Power Unlock          GREEN          (-)          AT BCM MODULE BEHIND DRIVERS SIDE OF DASH NEAR STEERING COLUMN
               PIN #12
     PowerLock          RED / YELLOW          (-)          AT BCM MODULE BEHIND DRIVERS SIDE OF DASH NEAR STEERING COLUMN
               PIN #9
     Driver Mtr Unlock          BLUE/RED          (+)          IN HARNESS IN DRIVERS KICKPANEL
     Driver Mtr Lock          YELLOW/BLACK          (+)          IN HARNESS IN DRIVERS KICKPANEL
     LF Window Up          RED          (REV)          AT VEHICLE MASTER WINDOW SWITCH IN DRIVERS DOOR
     LF Window Dn          GREEN          (REV)          AT VEHICLE MASTER WINDOW SWITCH IN DRIVERS DOOR
     RF Window Up          RED / BLUE          (REV)          AT VEHICLE MASTER WINDOW SWITCH IN DRIVERS DOOR
     RF Window Dn          BLACK/ WHITE          (REV)          AT VEHICLE MASTER WINDOW SWITCH IN DRIVERS DOOR
     LR Window Up          PINK          (REV)          AT VEHICLE MASTER WINDOW SWITCH IN DRIVERS DOOR
     LR Window Dn          BLUE/RED          (REV)          AT VEHICLE MASTER WINDOW SWITCH IN DRIVERS DOOR
     RR Window Up          RED / BLACK          (REV)          AT VEHICLE MASTER WINDOW SWITCH IN DRIVERS DOOR
     RR Window Dn          BLACK          (REV)          AT VEHICLE MASTER WINDOW SWITCH IN DRIVERS DOOR
     Sunroof Open          RED / WHITE          (-)          AT SUNROOF SWITCH IN OVERHEAD CONSOLE
     Sunroof Close          RED / BLUE          (-)          AT SUNROOF SWITCH IN OVERHEAD CONSOLE
     Note: Audiovox makes no representation or warranty with respect to the above information including its accuracy, completeness, or its freedom from third parties' proprietary rights. Audiovox disclaims all liability or responsibility for errors or omissions therein or any decision made by the recipient in reliance thereon. The installer must verify any circuitry with the proper test equipment prior to installation.
Tuesday, March 3, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
