2007 wrangler, remote start
kmitchell
Posted: October 28, 2007 at 2:45 PM / IP Logged
anyone know how to wire up the relays for remote start cant get dei document 1084
kevin mitchell
Platinum - Posts: 12,488
Posted: October 28, 2007 at 3:27 PM / IP Logged
Kevin, just use a bypass module that does the resistor 2nd start/ACC bypass for you. PATS-CHRYSLER04+ or the iDatalink ADS-TBCH-C2 will do the trick.
kmitchell
Posted: October 29, 2007 at 8:07 PM / IP Logged
thank you
kevin mitchell
fcss
Copper - Posts: 92
Posted: November 02, 2007 at 7:10 PM / IP Logged
velocity motors is right the Idata link peice is great I use them all the time but I have a different part number I dont know if this is an older part number or not but we use the ads-tbsl c2
extreme1
Silver - Posts: 1,070
Posted: November 02, 2007 at 7:38 PM / IP Logged
ads-al-ca + ads-rngc2 is the combo I use on all new chrysler vehicles.
Shaughn Murley
Visions Electronics
Red Deer, Alberta
Posted: November 03, 2007 at 7:05 PM / IP Logged
Wow, isn't that an expensive route to go ? Doing the ADS-TBSL-C2 is a WAY less expensive way to go because the ADS-TBSL-C2 has the chip built into the board on the module while the ads-al-ca + ads-rngc2 are two separate pieces.
Tuesday, February 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
