neon lights during remote start
bobs94
Member - Posts: 23
Posted: February 21, 2003 at 11:17 AM / IP Logged
I have a Viper 550 ESP alarm/remote start. I want to wire it so that my undercar lights turn on during the remote start process, but turns off when the key is in the ignition. I have an idea of how to do this, but I am not sure if it will work. I think I want to use the blue H3/1 status output wire from my alarm. Thank you for any help.
floaterr
Silver - Posts: 383
Posted: February 21, 2003 at 4:40 PM / IP Logged
Yes use H3/1
Connect on relay as follows
Both 85 and 30 to neons power source positive
     86 to the H3/1 wire
     87 to the postive feed to the neon
Good luck
camino
Copper - Posts: 54
Posted: February 25, 2003 at 7:55 PM / IP Logged
that's a good idea,how about if you do this:
#85 to parking light's output from alarm (+)
#86 to the blue wire that is negative during remote start
#30 to 12 volt constant
#87 output 12v to your neon light's
this way the neon ligths will do the same ligth the parking ligths,flash.of course if you would like it to flash.
ViperATC5
Copper - Posts: 202
Posted: February 25, 2003 at 10:17 PM / IP Logged
you can also program parking light output to remain constant throughout remote start
