2008 subaru impreza wiring?
vitrox
Copper - Posts: 96
Posted: November 13, 2007 at 2:51 PM / IP Logged
need to get this info, got the car sitting here right now, its not the same as a 07, looks like an 08 legacy under the dash but with different wire colors. anyone got em?
JWorm
Platinum - Posts: 2,208
Posted: November 13, 2007 at 6:33 PM / IP Logged
I'm on a Subaru forum and nobody there has posted any info yet. I do know that the 08 now uses the CAN BUS system. Good luck....and post your results if you could.
vitrox
Copper - Posts: 96
Posted: November 15, 2007 at 5:50 PM / IP Logged
here is the info i got.
12volt, white, ign harness
ignition, green, ign harness
starter, WHITE/ black, ign harness
2nd starter, WHITE/ red, ign harness
accessory, blue, ign harness
2nd accessory, yellow, ign harness
lock (-), lt. green, BIU 35 pin plug, pin 15
unlock (-), blue/black, BIU 35 pin plug, pin 29
parking lights (-), BLACK/ white, BIU 26 pin plug, pin 11
trunk release (reverse pol), BLACK/ blue, BIU 35 pin plug, pin22
brake, lt green, BIU 26 pin plug, pin 2
tach, gray/red, instrument cluster
thats all you need for remote start and keyless.  the factory alarm must be disabled because there is no way to disarm it without the factory keyfob. BIU is located to the right of the sterring column just like the legacys.  The plugs are all labeled by how many pins there are in them.  hope this info helps some of you out.
Wednesday, January 14, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
