07 sebring sedan, what bypass?
todds440
Member - Posts: 48
Posted: November 18, 2007 at 7:27 AM / IP Logged
Who's done a remote starter on a 07 Chrysler Sebring sedan?  What bypass did you use?  Any big hurdles or troubles that I should know about ahead of time?  I know newer Chrysler products can be a real treat!  Any one have wiring diagrams?  Thanks
tedmond
Gold - Posts: 4,610
Posted: November 18, 2007 at 7:39 AM / IP Logged
this car does have a transponder, u need a bypass kit to do so, and a few resistors for lock, unlock accessory and start. I think idatalinks are the best for ur application. one data bus wire should control all the things u need. less wires to cut.
Chris Luongo
Platinum - Posts: 3,746
Posted: November 18, 2007 at 9:25 AM / IP Logged
Those cars are pretty easy.
All you need at the steering column is one ignition, and there's a low-current negative starter wire.
No point in hooking up locks, since the customer will be carrying the factory remote anyway.
The least expensive bypass would be a blank Chrysler key and a universal bypass box........ you could use a DEI 556C or the equivalent from bypasskit.com, but I'm pretty sure that's more expensive.
todds440
Member - Posts: 48
Posted: November 18, 2007 at 12:51 PM / IP Logged
This isnt another Chrysler product that will only disarm the alarm with the factory remote?  Alarm R/S wont disarm factory alarm?
Saturday, March 7, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
